Question about Hitachi 53UWX10B 53" Rear Projection Television
53WUX10BA no power/sound/video but power light is on.
Hi, My 53WUX10BA is experiencing the same issue with, no power/sound with Power light on. I had the convergence board replaced about a year ago. I will replace both relays, but cannot find E907. Is it on the power supply board, convergence board, center board or far left board when looking from the back of the unit? When the power is on there is one led DP23 on the center board witch is not on, could this be of any indication as to which relay/pico fuse to replace?
I am a technician, but have no schematics for this unit and cannot get any as I am not Hitachi certified.
Any help would be appreciated
  • 5 more comments
  • blkmax Jul 16, 2008
    Could not find E907. I looked at the circuit involving DP23 and found that FP05 (3amp) is open on the DP1X Deflection board (right in the middle of the board).
    I will test everything in this circuit and replace FP05 if everything else is ok.
    I replaced FP05. Now the bord flashes led DP23 and DP35 and keeps beeping. Also RP24 is smoking and getting black. Also I marked the three high power red cables that goes from the lamps to the HV but did not mark witch ones went on the HV. There are three of them. Does it matter wich one goes where? As well to make things worse, I broke the steel connector inside the HV whe pulling on the cable. can I remove it, or do I need to purchase a whole new HV (labled TH01).
    I hope things go better.
    I was able to remove the steel cap from the HV and clipped the cable and resoldered thew cap on. the Service document does not show wich red cable goes to the HV. This is only high power right? so does it matter wich one goes to one or the other?
    thanks
  • blkmax Jul 17, 2008
    I found my awnser on the delfection page 2 of 2. They are all connected in parallel to TH01, so it does not matter wich one goes where. Still need to find what short is causing RP24 to glow orange. it's a .47ohm so it need quite a bit of current to get this hot.
    Making some progress, Isolated short into two lines on the deflection board 1/2 , B+ 115 V1 or B+ 115 V2. I will remove KG02 to try to isolate witch one tonight.
  • brianbolang Nov 17, 2008
    I have a Hitachi 53UWX10B projection color TV. When I turn on the TV, the power LED flashes but no power, no sound. I have tried un-plug the power cord for a few min and re-plug it in, it still does the same thing. Any help will be greatly appreciated.
    I have a Hitachi 53UWX10B projection color TV. When I turn on the TV, the power LED flashes but no power, no sound. Each time the LED flashes, I can hear a clicking sound. I have tried un-plug the power cord for a few min and re-plug it in, it still does the same thing. Any help will be greatly appreciated.
With KG02 removed, the short lies in B+ 115 V1.
Posted on Jul 18, 2008
TV has sound but there is not a picture. Model code: UN32EH5300FXZA Version No. UU02 Ac110-120v ~60hz 69W Typical power: 29W
Hi Ben,
Back light failure is a common problem with these sets. If it is so, I am afraid you can not repair it by yourself. You will need a qualified and experienced technician to handle it.
Jul 12, 2017 | Samsung Televison & Video
Hi I have a sony kp-53HS10 TV. When i turn it on it use to make a clicking noise and than the tv would turn on, but now the clicking noise is gone and nothing comes on. A red light under the tv stays on....
Sounds like a Power Board / Video Board issue - stand by power is still ok - and why you have a red light - but the set is unable to power up the panel to drive a picture. Or the video board is the issue an is no longer processing the image to your panel. Based on the clicking noise - I lean towards the power board as the issue.
Dec 21, 2017 | Sony KP-53HS10 TV
Screen is black. Power button lights up, fans and DVD seem to work.
hi there,
What you are experiencing with your laptop is "POST" (Power-on self test) issue. Here are some steps which you can try.
- Remove the battery and ac adapter (as well as external peripherals attached), press the power button for atleast 15 seconds, try to power on your computer again.
- If you have external monitor, hook it up. Display on the external monitor would mean that you have a LCD issue (check LCD cable, LCD inverter and LCD backlight in this case). No display on the external monitor would mean that you need to replace the video card (if dedicated) or replace the whole system board (if integrated).
- Try to reseat or replace the memory module as well, it might help.
Regards.
May 10, 2011 | Toshiba Satellite P305D-S8834 17 in Laptop...
My screen goes dark when I use my laptop. I have a docking station with monitor and the machine works fine. However when I undock or start up with just the laptop the screen goes black. I can still see...
Hi wilhejl,
I see that you are experiencing a video issue with you back light on this case,
you mentioned when docked on your docking station you see the video on you monitor but when undocked you get a black LCD screen and see shadows of what is on the LCD screen.
this is a back light issue that you are experiencing.
We can try and check some settings regarding this concern and se if there is anything we can do to correct what you are experiencing with your laptop
As soon as you turn your Laptop on keep on tapping F1 to will bring you to the BIOS screen if the BIOS shows up on you LCD screen without going black then most probably yo may need to change some settings in windows regarding the the LCD and power options.
  • Try docking back into your docking station and inside windows go to power options, and set your system power options to balanced.
  • On your Desktop right click anywhere on an open space to get the menu list click on personalize then click on display then click on advance settings, look for screen refresh rate change it to 59Hrtz then undock from your docking station and try booting into windows without using the docking station to check if the video will show on the LCD again on this issue.
I hope that this can help regarding your case,
Have a nice day.
Apr 07, 2011 | Dell Latitude E5400 Laptop
Light in the set box is not changing red light is flickering. Green light is not coming inspite of changing the batteries in the remote control. I am having Dish TV in my house.
Hi, this is Mary with Dish Network Customer Service. It sounds like you are experiencing a power issue with your Dish network VIP622 DVR. You can try resetting the Receiver box by unplugging it for 10 seconds (if it is plugged into a surge protector, for the purpose of troubleshooting, plug directly into a wall outlet). Wait for receiver to reacquire satellite signal. If you are still having an issue, you will need to contact Dish Network because the receiver box will probably need to be replaced. I hope this information helps you.
Sep 03, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Jul 28, 2009 | Nintendo Wii Console
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Wii will not turn on... no red light
Sounds like the unit may have experienced over voltage, there is a fuse on the board however I would take the easy route and test a new power brick to see if this solves the issue. Thank you
Feb 15, 2009 | Nintendo Wii Console
My 53WUX10BA Red Power light will not go out
will not power up it worked fine then last week it stoped turning on it just turns off as soon as i turn it on
Oct 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
125 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
