Question about Samsung LN-S4692D 46 in. LCD HDTV
Sound If I try to watch tv through the Home Cinema set up the lips are always out of synch with the sound
    Genius:
  • Samsung Master
  • 1,689 Answers
This can be from the source equipment, the program provider, or the way your audio system works.
The way to test this can be involved. It would mean using the process of elimination to determine where the delay is.
Jerry G.
Posted on Jul 26, 2008
Sound goes on and off while watching programmes every so often
This sounds like you have the device on a wrong sound setting. Check the sound settings. For example Dolby sound needs special settings.
Jan 13, 2016 | Panasonic 5.1 DVD Home Cinema System 1000W...
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
