Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Just moved into a house that has low voltage outdoor lights. They were working a month ago, but not sure what's happening now. Checked transformer. Lights work in the "on" position, but transformer makes a high pitched buzzing noise while on. If I put any other option for "dusk to dawn", "2 hrs", "4 hrs" etc... does not work. Any help would be appreciated. Thanks!
  • GlennMayer1 Jul 17, 2008
    Is there a way to "reset" the unit? The lights still come on when I use the on/off button. Or maybe it's the sensor? Sorry, but I'm just looking for an easy solution rather than buying a new one. It also seems the unit is hardwired to the house - no plug.
  • 1,512 Answers
Hi GlennMayer1
The high pitched noise you here is the switchmode electronic type power supply/control electronics malfunctioning. This could be caused by component failure in the power supply or a short circuit in the wiring preventing it from firing up correctly. Hard wiring a lamp directly to the power supply would allow you to check the system, but a replacement power supply is probably required.
Posted on Jul 16, 2008
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual '
Dec 09, 2015 | Malibu Hardware & Accessories
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
My Icon bathroom fan does not work by timer I have changed timer , transformer and electrics have been checked (with certificate) What next !
Which timer do your have?
Not all timers work with fan motors?
Are you adding a new bath fan? Or are you installing a new timer?
What transformer what checked? A transformer is used to change voltage. For example you can plug a Malibu outdoor-light transformer into ordinary 120V outlet and the transformer changes voltage to 12 volts so you can safely operate lights stuck into the ground around bushes. Or your phone recharges using transformer that converts ordinary 120Volt into very low voltage entering your phone.
Practically every electronic device in your home has a transformer ... microwave, TV, computer ... but I don't know why a bath fan would have a transformer.
Add a comment, and I will respond.
Aug 17, 2012 | Hardware & Accessories
Danby Designer 1.1 cu.ft. Microwave oven model DMW1158W I came home from work...went to heat up some lunch and the microwave didn't work. I thought maybe the power was was on. I...
Weird that it worked when you left then not. Have you had the lights inside of your house dimming off and on?? It could mean a bad neutral connection to your house from the power pole. That can cause the low voltage transformer on the timer board to burn out. So the fuse in the unit will not even blow but still kill the Low Voltage transformer. If sounds possible call your power company to do a "load test" on the incoming power lines to your house.. They don't typically even charge to do that. They take out your meter and put a tester in that spot that tests the supply to your house.
Oct 17, 2017 | Danby Microwave Ovens
Heat worked couple days ago. but today turned on the air and it worked but sometime it shut down and now furnace and air will not come on. check fuses in house and all are good. but have fuses outside did...
It is unlikely that you have a transformer at your outdoor unit. If your furnace has an electronic control board, look for a low voltage fuse that may be blown. The low voltage fuses used now usually resemble a car fuse.
May 01, 2010 | Goodman GMS90703BXA Heater
Thermostat wires dead
If you have a split system (an air handler that blows air into your house and an outdoor unit that has the compressor and condenser coil/fan), then you should look in the electrical compartment of your indoor unit and see if you can locate a low voltage fuse. This is usually located on the control board or between the transformer and "R". Make sure you shut off the power to your indoor unit first as they will still be 240volts available there. If the fuse is blown, replace it and reinstall your thermostat. Turn the power back on. If the thermostat is wired properly with no damaged wires in the process, the system should work fine.
If there is NO fuse, then check the low voltage side of your transformer using a Voltmeter. You will have to have the power on to perform this test. Be very careful. On one side of the transformer, you will read 240volts. The other side should read 24 volts. If there is no voltage on the 24volt side, you blew the transformer and will need to replace it.
Check these items first. If you need further assistance, let us know and we will dig a lil' deeper. :-)
24%20v%20transformer.jpgpicture of a typical transformer.
The low voltage fuse could be a glass cartridge fuse (systems typically older than 15 - 20 years old). Newer systems use the same style fuses that are used in your truck or car (ATC type).
Apr 08, 2010 | Hunter 30124 Air Conditioner
Power at 3 feet, not at 2 feet ???
You might need to check the power source for proper voltage, sometimes outdoor wiring is at the mercy of the elements. Rusty screws on recepticles and so forth. Another problem could be exposed wire in the line bleeding of to ground. Sometimes this happens if a fixture is removed and the wire not properly protected. If these are none of your problems just take up your fixtures and replace the wire. 16 guage underground feed will probably be less expensive than the transformer you bought.
Aug 08, 2009 | Malibu Intermatic Inc. ML121RT Low...
I want to find the transformer for the 36 volt inside unit. Is it in the inside unit or outside unit .I have no power to the inside unit however the outside unit has power,and the inside unit appears to be...
It's a 24v transformer. Your indoor unit houses the transformer for the outdoor unit. The outdoor has a low voltage (24v) supply running to it to push in the contactor for the outdoor unit to run. If your air handler inside has no power then it will kill your LOW VOLTAGE power to the outdoor unit. You will still have the high voltage power to the outdoor unit. You may have a fuse on the switch for your air handler blown if there is one. On the disconnect switch mounted to your air handler, you will have a door to open and a fuse in there. If not, check your main breaker at the panel. If you don't know what a transformer looks like, you may want to have someone familiar with electrical of HVAC help you. To check the transformer for power, you first need power to your air handler, which you don't have. I would say that is not your problem. I would assume your air conditioner is not running outside, correct? Your problem is the power (HIGH VOLTAGE) to your air handler. Loose wires, blown fuse, tripped breaker etc...
Aug 06, 2009 | Comfort-Aire HMC36AT-1 Air Conditioner
Airconditioner wont come on
Does the indoor blower come on? If not you might have a low voltage problem in your thermostat circuit or blown breaker or fuse for your furnace which energizes the contactor outdoors. If indoor blower runs check if their are any fuses in your outdoor disconnect.
Apr 30, 2009 | Heating & Cooling
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
224 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
