My washing machine will not stop filling up. When you switch it on and set it to run on a normal wash, it will start ok and pump out some of the water but then it doesn't seems to stop filling up with water and the drum then gets so full the washer floods. Can you tell me what part i need to fix this?
    President:
  • 1,462 Answers
Possibly no part at all.
take top off and locate the pressurestat. this is usually round with up to 9 elec connections and a small diameter pipe as well.
take pipe off and blow down hard and check no split in pipe.
to check pressostat itself, put on a piece of pipe of the same diameter. put machine on fill and gently blow into the pipe ie pressure. you should hear a click and the water will stop coming in
Posted on Jul 15, 2008
catriver
  • 878 Answers
SOURCE: Washer Tub Fills With Water When Washer is Not On
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Posted on Jan 21, 2007
jsrock516
  • 5911 Answers
I suspect you have a water inlet valve problem. When the valves fail, they tend to either leak by, or do not open at all. The symptom you are describing is typical of an inlet valve that is not closing properly. The leak may be minute, but over time, it fills the tub and over flows. To access the water inlet valve, you will need to remove the washer top panel. Remove the three screws in the back that hold the top in place and slide the panel straight back and lift off. The water inlet valve will be located on the left hand side in the rear between the fill hoses and the dispenser (as viewed from the front of the washer). If you wish to perform this repair yourself, you can find the part at searspartsdirect.com. Just type in your complete model number and the part can be located on the next page under the "Dispenser Parts" section as item number one (part #8181694). The replacement process is very simple. Just turn off the water source, remove the fill hoses, the dispenser hose and the mounting screws. If you need further assistance, please let me know. I hope this helps you.
Posted on Jul 03, 2008
  • 85 Answers
SOURCE: Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Posted on Jan 18, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
Posted on May 11, 2009
  • 57 Answers
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
Posted on May 18, 2010
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Intermittently stops and starts pumping water
may have something blocked in the pump outlet valve
your washing machine will let out your water if you put your pump hose on the floor
Jun 23, 2014 | Fisher and Paykel Washing Machines
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Already took off pump & cleared out $12 in change but still will not pump all water out or spin out. can hear pump running but think the damage has already been done. would it be pump or pressure...
If the washing machine won't fill up, make sure that the water supply valves are turned on. Next, make sure there are no kinks in the supply hoses that run from the supply valves to the washing machine. If nothing is obstructing the hoses, you may have another controls issue.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or filling too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fills a tube in the pressure switch. When the air pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Read more: Tips to Repair a Washing Machine ' eHow.com http://www.ehow.com/way_5435622_tips-repair-washing-machine.html#ixzz1C6BhALK0
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
When I start any program on my Miele Novotronic W820, the machine fills with water and drum starts to turn but after a short time the main wash light flashes on and off. I've tried clearing the program,...
you may find that the water pump is not operating properly as the first fill of water is normally pumpt out first before the wash fill is started unplug the machine and take the back panel off and locate the water pump and check if you can move the cooling fan at the rear of the pump freely if not the take the water outlet pipe off and remove whatever is stopping the rotation of the pump replace all parts and run the machine to see if the fault has been found and cleared eric
Jan 05, 2018 | Washing Machines
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
The washing machine will run a complete cycle perfectly, when i then empty it and refill with dirty washing, i put it onto the programme and press start, the machine sounds like the motor is running to...
On some machines when you start a programe the pump may run for a short while Restart machine and just give it a try for 3/4 minutes first just incase.
Sep 15, 2010 | Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
