Question about Belkin Computers & Internet
Unable to connect through a N1 Wireless router with more than one user using a IPsec connection. Only one person can cannot and the other gets a timeout.
  • 2 more comments
  • allinl Jul 15, 2008
    Hi, No I'm using windows XP. TRying to connect 2 Laptops wirelessly using Equant IPSEC connection.
    Both laptops are able to connect to the internet simultaneously without going through IPSEC.
    Could you clarify what you mean by a wireless network?
  • Lee Edwards May 11, 2010
    Have you setup a wireless network on both laptops yet?
    Are you using Windows Vista?
  • 50 Answers
In order for the laptops to see each other and allow you to work one with the other a network has to be installed and a work group formed.
1. Choose Start --> All Programs --> Accessories --> Communications --> Wireless Network Setup Wizard.
The wizard shows its splash screen.
2. Click Next.
The wizard asks you to type in a name for your network.
3. Type a name for the network.
The name of the network is used for the wireless router's SSID (Service Set Identifier), which the wireless box typically broadcasts to make it easy to connect. The SSID is the name that appears when you try to connect to a wireless network. Each wireless router has a default SSID: tsunami, wireless, and linksys are all common default SSIDs.
4. Unless you already have a network key that you absolutely must use, select the Automatically Assign a Network Key radio button.
5. If your wireless base station and all the wireless cards on your network support WPA (if you have 802.11g, they may or may not; with 802.11b, it's unlikely), check the Use WPA Encryption box.
There is a performance hit for using either WEP or WPA encryption. Your network will run slower — but your neighbor won't be able to look at your files. Fair trade, eh?
6. Click Next.
Behind the scenes, the wizard generates all the information it needs to set up a secure wireless network.
The wizard asks if it can use a "key drive" (USB flash drive) to set up the network.
7. Select the Use a USB Flash Drive radio button.
Select this button if you meet the following requirements:
• You have a key drive (USB flash drive) handy
• A free USB port is on every computer on your network
• All of the computers on your network are running Windows XP Service Pack 2 or later
• Your wireless router has a USB port and it understands WSNK (check the manual)
If you don't meet those requirements, then select the Set Up a Network Manually radio button. Then click Next.
• If you click the first button, the wizard takes you through the steps to transfer the settings to all the other computers on the network, as well as the wireless base station. Basically, you schlep the key drive to all the PCs, and they set themselves up.
• If your hardware isn't quite up to the **** Tracy stage yet, the wizard shows you its final instructions.
8. Click Print Network Settings.
The wizard doesn't actually print them. Instead, it opens Notepad and sticks the relevant settings in a new text file.
9. Print the text file and follow the instructions to transfer the settings to each of your wireless devices manually.
It isn't as bad as it looks. See the next section.
Making manual changes So you're stuck with entering wireless network security information by hand. Be of good cheer. The Wireless Network Setup Wizard (see the preceding section) does all the heavy lifting. If you're running Windows XP Service Pack 2 or later, it's pretty easy:
1. Enter the new settings in your wireless router or access point.
Unfortunately, each one is different. You may have to dig into the router's manual. Usually, once you get inside the router, making the changes is easy. The key you need to enter is the one that was generated by the Wireless Network Setup Wizard.
2. Make sure you update/apply/save the changes to the wireless router before leaving.
Many routers require you to save the changes manually, so they'll be around if the electricity goes out.
3. Choose Start --> All Programs --> Accessories --> Communications --> Wireless Network Setup Wizard.
You see that really confusing splash screen again.
4. Click Next.
The wizard asks for a network name.
5. Type the network name precisely the same way that it appears in the printout from the preceding section.
6. Select the Manually Assign a Network Key radio button and click Next.
The wizard asks you to type the key.
7. Click Next.
You end up at Step 7 in the preceding section, from which point you can print your settings or just close down the wizard.
8. Repeat Steps 3 through 8 on each computer in your wireless network.
Posted on Jul 15, 2008
Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Sep 07, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin n1 wireless router wireless indicator not solid
what do you mean not solid not staying still
it does that if downloading
or if another user is connected to your router
Jul 08, 2009 | Belkin N1 Wireless-N Wireless Router
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin - N1 Vision Router Unable to connect to the interste
Did you use the pass key to connect? If you are using the wifi you have to go to here with browser type admin for username and admin for pass and config the the router. To make life easy just use a cable ie Ethernet..
Oct 31, 2017 | Belkin (F5D5231-4) Router
Can't connect to Belkin N1 Wireless Router
when you reset the router to factory defaults everything goes back. so try to connect with cat5 cable and in IE link bar type and you will get the set screen of the router admin and password sholud get you in the you can look at the settings wep, etc. then change you pc to match
Mar 28, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Jan 07, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
101 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
