Question about GE Refrigerators
Water not draining from ice bin and ice forming on grid but not releasing into bin
  • 190 Answers
Dear customer,
if u are refering to a problem in your freezer then please check the following..
this should solve the problem.. thank you..
Posted on Jul 15, 2008
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
The Ice is not sliding out completely over grid
Limescale on the plate sticks to the ice. Descale with proprietary descaler and make sure the plate is scrupulously clean. If the timer is adjustable, give it an extra minute harvest time, and make sure condenser is clean as a whistle! Also check icemaker is level so block slides down onto cutting grid easily
May 07, 2012 | KitchenAid Refrigerators
Melting ice
The bin has most likely failed. Apparently the bin insulation on the DCE33 eventually gets saturated with water and loses it's insulation ability. Consequently the ice melts prematurely. Condensation starts to build up inside the bin because it's not cold enough adding to the problem as the water drips on the new ice inside the bin.
Mine is 5-yrs old and I was told that it's all the life I'll get out of it.
If everything else is workng properly, harvest time, cube size, cold water spray, then a new bin is the unfortunate solution.
Apr 02, 2012 | Scotsman DCE33PA1BC 15in Built-in...
GE Monogram ZDIS15 has ice (sometimes) getting stuck on freezing plate. It gets hot & tries to release, but only partially (sometimes works fine). I have cleaned with solution, run the cleaning cycle...
It is time to run a ice machine cleaner through the unit, instruction should be on the door. When you get a build up is causes your ice to bind to the evaporator plate and cause this problem. Most ice machines require cleaning every 6 month to prevent this. Use nickel safe cleaner only, and most of the time this will correct the ice binding on that evaporator plate.
I hope this helps
Aug 11, 2011 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Doesn't fill up
sounds like the ice is not releasing from the freeze plate before the waterpump comes back on. you can turn off icemaker - dry the plate with a towel - take fine steelwool and go up and down on the tray until all discoloration is removed and the plate is shiney - empty bin - flush plate and bin - turn back on and see if ice falls onto cutting grid either right before or right after waterpump comes on.
Nov 24, 2008 | U-Line Icemaker
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
