Question about E-Machines eMachines T3830 PC Desktop
Dvd/cd combo drive not working
I recently had to have my mother board and some other parts replaced in my system now after getting it back when i try and burn a dvd or just simply use my combo(it won't even read a disk that i put in,it actually doesn't even show that i have a disk in) the light flashes on the face of the drive but it keeps telling me drive not ready when i try and just simply burn an audio cd, did they mess something up or is it something i have to do? It was working fine before they put the new parts in!
    Scholar:
  • 162 Answers
If everything is hooked up right, I would check for drivers. Could be that you need a new burner.
Posted on Jul 25, 2008
  • 50 Answers
First I would call the company that did the work
I would hope they would stand behind what they have or have not done
With what you are saying my first thought would be to open up the computer and make sure the IDE cables from the DVD drive are connected, first to the drive, then to th motherboard
Posted on Jul 15, 2008
I connected my ide lg dvd rom using ide to sata adapter in my mother board as my mother board does not have any ide connection. so since ti gets detected during boot time but does not shows up or does not...
make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cdrw/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 02, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
I have a Samnsung SM-352N DVD CDRW Combo drive. But recently the drivers have got corrupted and I am unable to get back my DVD combo drive to work. In the Device Manager, the DVD CD RW drive is shown with...
control panel admistrive tools,computer management,device manager scroll down cd/dvd drives you should see a yellow question mark? right click to reinstall drivers or right click select enable or properties then general to troubleshoot or region select 4 you might uninstall reboot then reinstall
hope this helps
Oct 02, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cd writer program
Reinstall the program if you have a stand alon copy, or it may be on an application disk that came with your system.
Apr 26, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
LG Combo Drive
Try uninstalling the current driver, then applying the updated driver, worst case scenerio is you get the current driver again
Jan 29, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Samsung cd-rw drive sh-r522 problem
IF THE DRIVE SHOWS IT ,, then its hardware
eighter the drive is defective or something is wrong with the MB/P
try the drive on a different computer if it works change your mother board format and reinstall
if it didnt work take it back for warrenty or get a new drive
Dec 09, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
FAILURE OF CD READ/WRITE UNIT SONYCD-RWCRX140E
THERE IS A HARDWARE PROBLEM IN THIS, GET IT REPAIRED FROM SONY AUTHORIZED PERSON WITH SONY ORIGINAL PARTS. THINK THERE MUST ME PROBLEM IN LENS OF YOU DRIVE.
Nov 19, 2007 | Sony (CRX230E1/10S) CD-RW/DVD-ROM Combo...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Had some problem with connecting the DVD drive to the PC
Depend on what you have in your system already. If your are replacing and existing drive simply remove it, and replace on the same IDE cable making sure the jumper is set to slave. Assuming you have one drive to the 0-IDE connector and the other connector is is to existing CD and this new drive is to be a second one. You will need another IDE ribbon cable. Set the drive to Master- connect the cale. position and fix the drive and plug the other end on the cable to the second IDE connector [Drive 01] See you mother board manual - connected a spere power connector.
May 18, 2007 | Samsung SD 608 (SD-608) Internal DVD Drive
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
E-Machines eMachines T3830 PC Desktop Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
