Question about Smeg Dishwashers
SMEG MODEL DWI 64 - TYPE 12033 - Dishwasher. Alarm E3 shows and water does not heat up. Sometimes will go through complete programme ok. Alarm E2 has also come up but reset the trip switch in the base to correct. I'm pretty sure the heater element is ok. IN your court now - be most gratefull.
4 Suggested Answers
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 1462 Answers
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
What is fault E3?
E3 means that the heating element is operating when it should not be doing so. It may be caused by an older, weaker element that is taking too long to heat the water or the thermostat may be giving incorrect readings. Ensure you are using hot water to fill the machine (if tied to your faucet water supply, run the water until it is hot before starting the dishwasher). Information from the Belling manual:
If the heating element is still heating after the allowed time, then the control board will advance the programme to next step and at the end of the washing cycle the alarm buzzer will sound for 30 sec and the display will show E3.
When the control board detects that the heating element is operating during a non heating step or during the internal test the heating circuit is found to be open circuit then the alarm buzzer will sound for 30 sec and the control board will cease all functions except for the drain cycle which will run for 90 seconds and then E3 will be displayed on the control panel.
Mar 06, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Stops pumping in middle of program
I know it is a bit late, but maybe it would help the others.
This E3 error means, that the water temperature did not reach desired level (for example 60C if you are using 60C program) in a given time.
The dishwasher starts the heater and waits for example 10 minutes for the water to reach the temp.
The heater is located on the left side of the dishwasher - it heats
water flowing from the bottom bowl to the sprinkler on the top.
There can be few reasons:
- the heating device is dead - easy to check - if the water is hot when E3 appears, then this is not the case
- the water duct from the bottom bowl to the top sprinkler is messy, and needs cleaning (there are some rubber pipes of quite small diameter)
- the temperature sensor (thermistor) is dead / not responding fast enough. It is mounted to the bottom bowl and can be reached from the front cover, under the doors.
Hope it would help to somebody.
I have already had this and few other problems. All of them have about 5-6 reasons to appear, and I think I know all of them for now :-)
For me, knowing what to expect and how to fix each E-something, this dishwasher is perfect and will last forever :-)
Regards,
Piotr
Jan 19, 2009 | Candy Dishwashers
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
just possibly
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Water pre-heating
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Dishwashers Logo
122 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
