Found the codes are printed inside the air conditioner. F33 ---01. = locked up compressor. Cannot fix this problem myself, will have to engage a serviceman. Stan.
H00 is code showing the system has no memory of an error so you could try turning the power off for 15 minutes then back on and see how it goes. Power supply fluctuations can sometimes make Panasonic A/C's do funny things. If the fault recurs, you will have to get a tech to diagnose.
The F33 error means that the washer control unit didn't get the expected response from the drain pump drive during a self-test (before starting the washer cycle). This is usually a wiring issue. Unplug the washer and drain out any water in the unit. Remove the clothing and pull the washer out so that you can reach the access panel. Take a look at the wiring between the drain pump and the CCU (control unit) DP2 connector. Make sure that all of the wiring harnesses are connected. Look for any broken wires or ones that are detached from the wiring harness. With an multimeter, check for continuity in these wires. If there are any broken wires, replace the wiring (Main Harness).
If the wiring is okay, check if the drain pump filter is clogged with a foreign object. Disassemble the drain pump and check if the impeller is intact and on its shaft. Replace the pump if the impeller is damaged. Reconnect the power to the washer and check if the error recurs.
I hope this helps. If you add a comment with the model number, I may be able to provide more information on the parts.
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit). Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
5d
possible causes
* If too much detergent was used
-Run the unit thrugh a RING/SPIN cycle.
-Run a NORMAL cycle with out adding detergent.
PROCEDURE
* This should clear the unit of execess detergent.
1.- Check the draing hose and male sre it is not plugged or ****.
2 Unplug washer or disconnect power.
3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU).
4.- Check/clean drain pump filter of foreign objects.
5-Plug in washer or reconect power.
6.- Check draing pump.
7.- Check the pressure switch.
8.- Verify CCU operation bu running a Diagnostic Test or any cycle.
F33
MUST be fix by a technition Service ONLY am sorry about this inconvenient.
"Was this helpful?"
Aircon has been in service for a long time now give error 33
when swiched of and then on again will run for some minutes then error again
condenser shuts down
