Question about Motorola Mobility MPx220 Pocket PC
Files copying fails
Files copying from desktop to device is ok, but does not getting copied from device to desktop. please help me ,what is the problem. thank Q
  • 3 Answers
Check that the file is 'Read Only'..........if so uncheck that in file properities from ur phone........and u can transfer from fone to PC......
Posted on Mar 06, 2009
I have just purchsed a 4gb usb2 flash drive . I am wanting to copy some pictures from my desktop and put them on my new laptop . Can anyone tell me how to do this in simple language as i do not understand...
Hi. All you have to do is:
- Insert your new USB flashdrive in an empty USB slot in your desktop computer.
- A new window will appear and will ask you what you want to do with that device... Choose "Open folder to view files".
- Then just leave it there and go to the file(s) you want to copy, right click on i and click "copy"
- Go back to your USB folder, right click on an empty space on that folder and click "paste". That will copy the files into your USB flashdrive.
- Remove the USB flashdrive from your desktop.
- Insert it into your laptop's empty USB slot.
- Highlight all the files you want to copy from USB flashdrive folder, right click and click "cut".
- Go to your laptops folder where you want to copy the files, right click on an empty space and click "paste".
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
I have changed PCs and I am attempting to install Garmin's BlueChart Pacific CD into a PC running XP Professional 2002 with Service Pack 3. The setup aborts immediately after starting the installation...
maybe it isn the pc but the cd try this..
1.) create a folder on the desktop called something
2.) click start / my computer / Right click on the cd drive with the disc in it and click open
3.) select all the files (edit select all)
4.) copy them (edit copy)
5.) go back to the folder on the desktop and paste it in the folder
(edit paste)
7.) double click on the setup file to install it
NB ::: if the files fail to copy its cause part of the cd is damaged and thats why the instillation is aborting.
If the files copy and the instillation still fails then please post the failure message here so we can review it and guide your further.
Jul 23, 2008 | Computers & Internet
How to repair missing wininet.dll?
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Aug 07, 2010 | IBM NetVista PC Desktop
No sound
if there is a x near the speaker (top right) on today screen then tap it and tap ON and the sound will be back.
If you have deleted sound files copy few .MP3 files in "My Device\Windows" for ring tones And copy few .WAV files in "My Device\Windows" for SMS tones.
Jul 04, 2009 | i-mate JasJam Smartphone
Gets error related to lxdnlscn.exe when I push the scan button on the printer.
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
First, unplug the USB cable. Next, please download the clean up patch from the link given below:
ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
Click on "CleanupUtility.exe" file.
To apply the cleanup file, copy and paste the icon on to your desktop and double click the file to run the file.
Please download and install the Windows Vista driver from the website given below in order to resolve the issue:
www.lexmark.com
Please click on "Drivers & Downloads."
Select "Driver Finder" and under "Search by Model" Please enter the printer model number "Lexmark X2690" click on search.
Please use the following steps to download the Lexmark X2690 Vista driver to your desktop:
1. Select "vista_x64" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark X2600 series printer and scanner drivers.
May 23, 2009 | Lexmark X2600 InkJet Printer
Not able copy folders from able to copy folders across from Passport drive onto PC desktop
hmm..is the drive visible in the my computer panel? and you could do a global search and copy and paste if that goes quicker..
Oct 15, 2008 | Western Digital Passport WDXML800UE...
Trasfering emails and contacts from Windows Mail to Outlook Express
Hello
you can do it in many ways but I think this is the simplest.
copy addressbook
1. go to file>export>windows contacts
2. and save it to same backup folder on your desktop
copy msg
1. create a folder on your vista desktop(backupmail)
2. start vista mail
3. drag your messages that you want to the XP computer to the desktop backup mail folder you most drag emails you cannot drag and drop folders.
4. when you are done move the folder on a USB stick or something and move it to your desktop on your xp computer.
copy addressbook
1. go to file>export>windows contacts choose CSV
copy your mail account.
1. go to tools>accounts>export
2. save the file in you backup folder on your desktop
then copy the backup folder on your desktop to a usb stick or something to transfer it to your xp computer
your xp computer.
import msg
1. paste the backup folder to your desktop
2. open outlook express and drag and drop the msg from the backup folder on your desktop
import contacts
1. click file import "other addressbook" and choose "text file" navigate to the desktop backup folder and you should find a file to import click OK.
import account settings
1.go to options> accounts
2. then mail tab and click import button
3. navigate to the backup folder on your desktop and choose the iaf file to import
then you are done
good luck hope I helped, get back to me if you need more help.
Sep 18, 2008 | Microsoft Windows Vista Ultimate Edition
Hard disk stops copying
sir,
first you scan pendrive with anti virus Soft ware why mens i think virus probalm your pendrive ok check pendrive witch company pendrive sir give me details full ok have a nice day by sir
Mar 14, 2008 | Computers & Internet
Copy heavy files fail from iRiver to Hard-Drive
That is too many songs to transfer at once - transfer less at a time
Oct 10, 2007 | iRiver H10 MP3 Player
Motorola Mobility MPx220 Pocket PC Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
