Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WD64 Washer Dryer
Has developed a problem as the machine is not draining the water way.Have checked for blockages and all is clesr
  • 4,889 Answers
Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires getting loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Lay the washer on its side(If possible) and clean out the hose. If it still doesn't work then its time to get a new pump assembly. Good luck!
Posted on Jul 15, 2008
  • eagle338
    eagle338 Jul 15, 2008
    By the way the cost of pump assembly for your washer is around 100$.
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Wd64 thermostates keep going
Need more details on this as I am not familiar with model numbers...washer or dryer....describe in some detail what is happening.
Feb 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Cold feed only
i don't see why not, you only be able to wash in cold water and i hope u have a drain and power in that room.
Dec 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1200 washer dryer wd64
operation will be affected by having only one hose connected - when water from the disconnected hose is demanded then machine will not continue. i assume hot hose not connected. easiest way to deal with this is to connect both hoses to a ~"y" piece. easily available and costs about £3
Jul 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
244 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
