Question about Lands Phones
Messages are cut off at the end
When someone calls and leaves a message, the ending is cut off.  I left a message on my machine and the "goodbye" was completely cut off and the machine immediately stated "end of message".  Is there anything I can do? Thank you, Laura
  • laurathomas Jul 15, 2008
    There isn't a time limit on the phone.  Thanks anyway.
  • 97 Answers
Maybe you havea time limit that it can record for. or maybe it is onthe line you use and not the mahine.
Posted on Jul 15, 2008
How do i get rid of the voice mail icon on my phone when theres no voice mail left
You might need to go to an area where there is excellent reception and pull the icon down and redial message machine. Listen to the options first to make sure non saved messages. If so delete. If no saved messages you should now be able to end call. This should clear it. If still there try a reset.
Feb 28, 2017 | Cell Phones
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
This also maybe useful
Delete Inbox Messages Blind Nokia Broken Screen
Press left once
Press up once - Message Menu
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
Staticky messages
these machines are all digital, so the static is most likely being picked up from the callers end or your end or your machine just is not working properly. in most cases it is a telephone line quality problem.
May 04, 2010 | Vtech Digital Cordless Telephone VT-2568
I have a bell answering machine model AN200SA. It is not recording messages and therefore there is nothing to play back. But we can hear the person leaving a message when they call. I do need to try fix...
I have a Bell Phones answering machine model: AN-200SA. It is not recording the messages. We do hear the caller leaving the message. Need to fix urgently. Please can someone kindly assist me!
Oct 20, 2009 | BellSouth Lands Phones
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
How to record messages
It sounds like two separate problems, MaryAnne44. I have the exact same machine, but don't have that problem. Sounds to me your machine is ready for the scrap heap.
Nov 30, 2007 | GE 29875GE2 Digital Answering Machine
Error message 8 - won't record call
Here's how we fixed it. The official solution in the manual is to unplug the machine for 20 minutes. That didn't help. Apparently, we needed to do it for longer. After we left both ends of the power cord (from the wall and the machine) unplugged for about 5 hours, the machine magically worked again -- and no more code 8.
May 18, 2007 | GE 29871GE3 Digital Answering Machine
Lands Phones Logo
227 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
