Question about Arris Touchstone 450a (CM450) Modem
My pc won't connect to the internet
How do i stop my modem from recognizing the IP address of my notebook and get it to recognize the IP address to my desktop without a router.
  • 3,940 Answers
It is the MAC address that needs to be scrubbed from the modem.
power off the desktop, power off the modem, unplug the data cable from the modem, unplug the POWER connection to the modem.
WAIT 3 MINUTES
Connect power to modem, let it reset
Connect data cable to Modem
power on computer
Modem should now connect & work with desktop.
Each time you switch between systems, you may have to do this. More than enough to make me buy a router. =)
Please rate the post. =)
Posted on Jul 15, 2008
Hey, i recently reformatted my mx6453 so im back to the old win xp sp2. reinstalled all my drivers but for some reason it won't recognize an internet connection of any kind. at first i though it w
If your driver are ok then is your computer is in same WORKGROUP like other are(If you are in LAN connection and sharing internet with other).
was there any IP address in your computer before you formatted it? make it confirm and if IP was there then give back the IP to tour connection.
Aug 08, 2012 | Gateway MX6453 Notebook
How do I get my HP Pavilion N5150 to recognize my modem for roadrunner internet.? I don't know what kind of external modem it is, DSL or cable, but from what I understand I should just be able to plug...
If the modem connect to a coaxial cable its cable, if connect to a RJ11 aka Telephone cable is DSL. Most of the modems connect the computers via RJ45 aka Cat5 or network cable. For this type of connection you do not need drivers.
If the computer not connect to internet, check for the NIC card driver in COntrol Panel. If the drivers are good, then open the command prompt (go to START | Run.. | Type cmd and press ENTER) and type ping 127.0.0.1, if you not have a success the network card is bad. If successfull...
Type ipconfig, if you have return IP of 169.254.x.x then your computer is not getting an IP. reset the router and check again.
When type ipconfig you have to display one of these IP address . 1) 192.168.x.x 2) 172.16.x.x 3)10.0.x.x. If you cant connect check for third party software installed.
Jul 08, 2009 | HP Pavilion N5150 Notebook
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Limited or no connectivity to internet
hi the best solution is that to download the modem driver cd for ur system. install that modem driver cd and the connect to internet. it will surely work out for u.. pls rate me
Jan 21, 2009 | Compaq Presario C700T Notebook
My computer keeps telling me I do not have an internet connection when I connect my router. I can unplugg the router and plug it back into my dsl modem and the internet again works. why won't my router...
More info would be helpful, but I am assuming that you have a router device that is not the DSL Modem, maybe a linksys, or something? Most likely what is happening is that the DSL modem is assigning private IP addresses, like 192.168.1.x, and the router is obtaining that IP address on its WAN interface, but is also configured for the LAN at 192.168.1.x, which is the same subnet, so it cannot route packets to the internet properly, as both interfaces have the same network range. Can you give me more info? I can try to walk you thru step by step.
Step 1. Verify current IP address when internet connection is working. (Go to a command prompt and type ipconfig, press enter, and document what your IP address is, also document the gateway address and subnet mask)
Step 2. Connect to the router instead of the DSL modem, do the same thing, document your IP address, gateway, and subnet mask
Step 3. Compare the two, your IP may be different, and the gateway may even be different, but see if both are trying to use the same IP range.
If they are the same, or close (the first 3 octets(set of numbers) are the same) then you will need to configure the lan side of either your DSL modem, or the router to be on a different IP address.
To do this will vary depending on the model of your router, so if you respond in the next few hours, I will still be online, and will try to assist.
Apr 23, 2008 | Computers & Internet
Dell latitude d800 laptop
The problem may be the modem has to assign an IP address to your laptop, what you may have to do is plug the laptop into the modem and see if the laptop recognizes the modem with no errors in device manager,
Next turn off the laptop and modem, reboot the laptop then modem for the modem to assign an IP address.
Mar 19, 2008 | Dell Latitude D800 Notebook
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Arris Touchstone 450a (CM450) Modem Logo
417 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
