Hey there, I was trying to
Hey there, I was trying to install my Brother DCP-560CN on my Windows XP system and got the error after reboot: "Failed to start the ControlCenter. The required registry information is missing. Please re-install the Multi-Function Suite. (CC3-001-00001907)" Now the printing and copying are working fine, but scanning is not. I tried the installation on a Vista system and all the functions work well. Hoping to get some advice, Cheers!
  • 2 more comments
  • zxcus9 Aug 26, 2008
    I get the same Error Message but on my new Windows Vista pc when I tried installing my Brother MFC-665CW printer, scanner, fax machine and the Brother web site is not clear as to what to do. I cannot uninstall the printer driver either. Thanks!!
  • lilly332 Oct 03, 2008
  • Anonymous Feb 19, 2009
    I'm running Windows 7 and using compatibility mode I can install it with a few hiccups. But the CCC3 and ink monitoring don;t work at all, giving the same error message.
  • eliteoz Mar 05, 2009
    Installation appears to work fine on Windows XP but on re-boot the error 'Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907 comes up. Re-installation does not fix it. Snoozing Virus software has no affect. The Brother Model is MFC-685CW
I guess I found a solution for the problem.
I also got this error message after installing ControlCenter3. Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907. The numbers at the end can change, but that's not important.
I have two laptops running vista. I got this error with the 1st laptop. Then I tried it with the second laptop, it worked fine. That made me think: On the first laptop I had tried to install the ControlCenter3 from the CD, but it turned out that the CD did not support Vista. Then I got the vista driver/ControlCenter3 package from the Brother website. This is the one that did not work on laptop one. What I then guessed was, that I had some ugly remains from the installation of the old driver (not for vista). I started cleaning the registry. First of all I run the driver uninstall program from Brother (free from their website) then I cleaned the registry with CCleaner (freeware). Still that was not enough. I started the regedit program and started searching for the term Brother. It was still there in about 10 or more places. I deleted all records that were connected with my brother printer (a DCP-130C). Then I run CCleaner once more. Then I installed the vista driver package (from brother website). Restarted and voila: it worked. ControlCenter3 workes fine now. I started the ControlCenter3 update (also on brother website) and finally with the scanner utility put the scanner resolution limit up higher. That's it.
Before working with the registry make a backup, please.
This procedure should also work for other brother printers using the controlcenter3. It should also work for other systems than vista.
Cheers, hope this was helpful.
Edi
Posted on Jun 11, 2010
DCP-165C
Posted on Apr 22, 2009
2 Suggested Answers
Kaiji
  • 66 Answers
SOURCE: Using Windows 7, Trying to
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Posted on Mar 28, 2011
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Can I network Shinco printer s2145
with one of these
http://www.dx.com/p/network-usb-2-0-lpr-printer-server-10-100mbps-ethernet-31570?tc=AUD&gclid=CP-1weaL9MICFRUIvAodEpYAZA#.VKXrgHs_zLk
Only thing is I did not find windows 8 drivers for this printer as standard so you may run into trouble with computers running windows 8 as each computer has to have the exact operating system printer driver designed for its exact operating system .
Unless you can find windows 8 drivers somewhere on the internet
Jan 01, 2015 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
2,152 people viewed this question
