I have a Hi-Grade laptop and I have the audio volume turned right up..When the laptop starts up the sound is at normal volume..but when playing videos/listening to music etc..I can hardly hear anything!
bsrjth
  • 270 Answers
SOURCE: w880i no sound
press (then on jotstck press left and right as in order given)
R-right
*- star button
L -left
R*LL*L* this open service menu of phoone go to service settings check sound and buzzer setting if there also the sound is not working . consult an service center
Posted on Dec 04, 2007
SOURCE: Low sound volume when watching DVD's
(bad english warn)
so... i just found out that i had turned almost to 0 the volume on Nero ShowTime... and it just gets the windows volume down not just for that program bt everything... even winamp got itself on maximum volume and i couldnt hear almost nothing in all my sound system with the volume at max.
so heres the solution...
OPEN YOUR DVD PLAYER (nero ST or whatever it is) AND TURN VOLUME TO MAX. AND ONLY DECREASE IT ON WINDOS (SPEAKER ICON)
Problem Solved
fell good to help!!!
best regards from Brasil
Posted on Apr 12, 2008
  • 111 Answers
SOURCE: Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Posted on Apr 29, 2008
  • 22 Answers
SOURCE: Audio problem with acer aspire 5920
hithere your best bet is just to go onto the acer site and they will have all the updated drivers for windows vista on there. i had the sameproblem with my laptop which is also an acer. any problems then just emial meon milliprowd21@yahoo.co.uk.
you can find the site by googleing acer support drivers
regards
matt
Posted on Aug 21, 2008
  • 50 Answers
SOURCE: People can hear me speak but I can't hear them
Sound inducers do go bad. Normal the same audio amplifier is used for both the ear piece and the speaker. Since the speak does work, it sounds like the ear piece has died.
Posted on May 28, 2009
Low headphone volume on laptop
Hi , is the sound working ok on the pc speakers or is it the same.
Apr 09, 2013 | Computers & Internet
Hi grade laptop wont allow sound to come from the speakers
Make sure that the audio isn't muted.
On the little speaker in the lower right hand corner of the desktop double click on the speaker and make sure it's not muted.
Jul 07, 2012 | Computers & Internet
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
Volume buttons on my toshiba laptop is not working
There are other ways to adjust the volume.
Right click on the megaphone located at the bottom right near the time. You can adjust the volume there.
Look on your keyboard and normally you can Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys with the megaphone that adjusts the volume (1 key increases the volume, 1 key decreases the volume and 1 key mutes the volume).
You can adjust the volume in the Control Panel's audio or sound properties. Click Start/Control Panel and look for Sound or Audio.
May 04, 2012 | Computers & Internet
No sound but external speaker works
Hi
Do you have the sound actualy turned on or activated you could check it out if you go to
start
control panel
sound/audio
and check it out
also there is normally a sound up and down tab somewhere on the keyboard or just above or on the front and normally if you press the FN at the same time as the volume tab one can turn it up or down
Jan 24, 2011 | Computers & Internet
I change OS from vista to xp now iam not able to play audio or video files. Message says sound driver either missing or used by another program. No volume logo is seen in taskbar. plz help
Hi Thanks for your question
You need to get your Audio drivers in order to do this:
1. Put your manufacturers name in google search engine 2. Choose a home page of producer of your laptop 3. Once your in there choose support/download section 4. It should normally take you through the process of finding certain model of device 5. Once you find drivers for your laptop download Audio and install 6. Restart your computer and everything should be back to normal
I hope this helps
www.vtech-computers.co.uk
May 16, 2010 | Computers & Internet
My lap top has stopped playing audio
Right click the volume control - select open - this will open a larger volume control showing the volumes for each type of sound. Make sure none of the sliders are muted or low.
Apr 20, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
No sound
Check the speaker icon in the taskbar at the bottom, if there is an X then it is muted. Right click to unmute.
Also as it is a laptop there may be a mute button on the keys using the function button and a typical mute icon on a key or even a seperate button altogether.
Mar 18, 2009 | Microsoft Windows XP Home Edition
HI-GRADE Intel Core T2080
Hi.
Intermittent faults like this are very common in laptops. It is most likely cracked soldering on the mainboard. Sometimes it can be repaired, or it may need a board replacement. Unfortunately, paying the big money doesn't mean high quality these days. Just look at the failure rate of Apple laptops as a good example. A friend of mine has had 16 failures in the top spec Macbook.
Jan 04, 2009 | Computers & Internet
Sound
Try this....
Locate the volume knob (toshiba laptops normally has this volume know located on the side of the laptop). Make sure it turned on. and see what happens. Even if the sound icon in the taskbar is turned up but if this knob is not then there would be no sound at all. I am assuming that your drivers are good since you said in the device manager that all are working properly.
hope i was able to help
Apr 08, 2008 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
