Question about NAD C320 2-Channel Amplifier
Nad 310 amplifier VERY QUIET
Hello, i have a Nad 310 amplifier and at the very maximum volume I have a high volume but not something my neighbours would complain of.
This is using a mixer and cd player.
If I use it for my TV instead the volume is really low.
ay idea?
thanks
  • 1 more comment
  • edy piro
    edy piro Jul 15, 2008
    thanks marsover,
    I forgot to say that i have tried to plug tv audio out in all the inputs and the result is the same amount of weak volume, the sound is good but it's just quiet.
    If I plug my cdj to my mixer and to the Nad 310, then is louder as the mixer is a pre-amplifier, but still not what it used to be at max volume (at all!)
    At the moment I opened it to see if there is any dried capacitor (as i saw a previous post for another amplifier), but thy all look ok to me ( i can post a picture tho...)
    any other idea?
    thanks a lot!
  • edy piro
    Tried that.
    Tried also other sources, and I also used the front input for ipods (etc.) same low volume overall...
  • edy piro
    edy piro Jul 16, 2008
    no luck different cable or sources or tv set up ( even at a friend's house)
  • 682 Answers
Take audio out from tv and insert it in aux in in your amp.
Posted on Jul 15, 2008
  • mohamed eltoni
    mohamed eltoni Jul 15, 2008
    change your cable and check again-and check setup in tv and put it in stereo mode(if you have it in your tv)
Can you still get a new volume control pot for a nad 310 intergreated amplifier
I don't see why not. Just get the value of the pot off the numbers on the back of it or measure it
Aug 30, 2016 | NAD Audio Players & Recorders
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
Hello I'm looking for a NAD T753 Service
Hi DERAIN Francois,
First of all, thank you for purchasing the service manual of NAD T753.
Please email me at mjsvillanueva23@yahoo.com I will send to you the copy. It is a PDF file format and can't be upload here.
Again, thank you so much!
Take care and have a great day!
Rating and feedback are highly appreciated.
mjsazon
Feb 06, 2012 | NAD 712
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
Nad 310 no power
The output should be 24v ac. Sounds like you have a busted transformer. Did you check out the resistor in front of the transformer.
You sound like you know what your talking about so I will not bore you with suff like glass fuses and thermal couples.
Good luck, I have had a few items like this over the years. Sometimes it's just best to send them in to the manufacture. I would look for a replacement transformer. 120v ac to 24v ac around 5 amps. Test it out and see if it works... If not, send it in.
Jan 22, 2009 | NAD C320 2-Channel Amplifier
Knob for NAD amp?
Hi...
try your "local" NAD seller and ask them?
Contact NAD by email.
or
www.audiokarma.org
100's of users someone there should be able to help.
Jan 11, 2009 | NAD C370 2-Channel Amplifier
Cuts out when volume increased
it went to protection mode check your cables first and then check your speakers-and confirm no cable touch each other(try with another speakers had same rating)(watt)--means how much power can get.
Jul 28, 2008 | NAD C320 2-Channel Amplifier
NAD C320 2-Channel Amplifier Logo
996 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
