Can I connect my Samsung flet screen TV to my computer and do away with my computer monitor ? If so do I require a special connection between the two ?
  • 97 Answers
Yes, see your computer specialist.
Posted on Jul 15, 2008
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Jan 02, 2014 | Samsung SyncMaster 400PX 40 inch LCD...
Samsung 920nm sync master Black screen
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
Jun 20, 2012 | Samsung Computers & Internet
Connected acer laptop to my 47inch samsung tv. display is showing on tv but laptop screen is black
Some computer brands will automatically turn off the laptop screen when external monitor or Tv is used, the reason for this is that the motherboard does not have to work any harder than required, because a lot more resources are used when two screens are used and the ware and tare on the motherboard will be heavy and life span will be shorter.
Apr 22, 2012 | Acer Aspire 7740G6364 (lxplx02165) PC...
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
Screen goes from digital to analog.
Unplug the analog cable from the system, and leave only the digital cable connected, and if u require to use the analog in future, then you can connect that as well
Nov 13, 2010 | Samsung SyncMaster 220WM Monitor
Samsung lcd monitor 933fn service manul
Try the following options:
Option1: Remove the cable that connects the monitor to the CPU. Just straighten it and see, if there is any bulge or darkening on the wires.
Option2: Monitor's screen can get magnetized by other sources of magnets like speakers. Move away speakers from your monitor first then Try "Degauss" . Find it in Monitor's Menu.
Mar 09, 2010 | Samsung 933SN Monitor
I had my computer repaired and now my monitor doesn't work when I connect to the computer.
Make sure you connected the cable to the correct monitor port. A lot of newer computers have two ports to run two monitors at once. This requires a special setting in the video display preferences.
Aug 07, 2009 | Envision Computers & Internet
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Jul 30, 2009 | Samsung SyncMaster 920NW Monitor
REDDISH Screen with Samsung Monitor
You should changes the connections first!!!
Monitor connected directly to TV/ CPU without passing the projector unit.
I think that's the problems!!!
Dec 19, 2008 | LG Flatron F700B 17" CRT Monitor
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
