Washing machine program does not complete. drum does not empty
  • 27 Answers
If the drum is not empty, then you may have a pump problem. Most pump problems are simply blockages. Check this area first, REMEMBER ALWAYS TURN THE POWER OFF FIRST
Posted on Jul 15, 2008
Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
Dec 06, 2014 | Hoover Genuine Candy Zerowatt Washing...
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
When the water drain, the machine just make noise and the drum stay still for more than 10 minutes based on the timer countdown. Then I pause and start. Noise & no movement. However this does not happen at...
Angie This happened to my washing machine. What I did was I tried some programs , empty, spin, short washing. After I had tried quite a few programs it started working correctly again. It is worth trying. Kolbrun
Sep 19, 2013 | Electrolux Washing Machines
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
Jun 16, 2009 | Hoover Washing Machines
Zanussi will not empty
Hi
remove filter from bottom of machine and clear any debris which is in there and check impeller is turning ok.
regards
Mar 01, 2009 | Zanussi ZWF1430W Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
