Question about Acer Aspire 3680 Laptop
Headphone Jack not working
Hey there - I've had my notebook for nearly two years now, and for about the same amount of time I've had the following probs:
1) CD/DVD's play at half speed, really broken viewing/listening;
2) The Headphone Jack is really temperamental, and only works sporadically..
Please, any help ?????
    Sergeant:
    Champion:
  • 327 Answers
Welcome to FIXYA
first off for the cd/dvd problem goto control panel >system and maintenance >device manager and make sure you have up to date drivers and if yes then i would do a disk clean and a defrag of the computer as for the headphone jack i would do the same thing it might just need the drivers updated
i hope this helps out if not let me know have a good day :)
Posted on Jul 15, 2008
Headphone jack not working
Do the speakers still work? If they do most probably the connector jack is broken, you can either send it to a service rep to replace (which costs a bomb and takes a better half of a year) or you could get a USB to Headphone/Microphone converter which costs about 5-8 Euros
Mar 16, 2014 | Dell Latitude D410 Notebook
Laptop speakers work for 5 minutes before making no sound
it sounds like a fault in the speakers themselves. It's most likely a physical fault as the computer seems to think that everything is working okay. do you have a different set of speakers to try and see if the same thing occurs?
Dec 02, 2013 | MSI Microstar CR640 PC Notebook
I reinstalled my operating system after that my speaker disn't work
Sound is not working. Headphones would work just fine but the built-in speakers stopped working. try to update and reinstall the drivers. The speakers would sometimes work for a second when removed the headphone jack. sometimes it was a short in the jack connection or just a bad connector in the jack. Sooo, just plugg in the headphone jack a bunch of times and after about 20 seconds the speakers will work just fine.
Dec 14, 2010 | HP Pavilion dv6000z Notebook
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
Sound comes from both speaker and headphone of my compaq c770tu laptop what can i do ?
Do the following:
Unplug laptop cord and remove battery to reset the laptop.
Restart the laptop wint headphone jack IN.
After Windows has restarted with headphone plugged, while windows is on, unplug headphones and restart Windows again with headphones NOT plugged this time.
Aug 15, 2009 | Compaq Presario 700 470024-192 Notebook
No voices come out, sound is good, with headphones and speakers
This sounds like a problem with your connection for your headphones. Your headphone jack on your notebook is stereo, which means that you need stereo headphones to make it work. If you look at the tip of your plug on your headphone cord, it will have 1 black ring, or 2 black rings. 1 black ring is mono, 2 black rings is stereo.
If you are using stereo headphones, and you're still having this problem, your headphone plug is not going all the way into the jack on your notebook. Press the plug all the way into the jack and the problem should be fixed.
If you physically cannot push the plug all the way into the jack, there may be a problem with the jack on your notebook that will need to be looked at.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 15, 2009 | Compaq Computers & Internet
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Aspire 3680-2574 Headphone jack
did you try another set of head phones? the jack for the headphone where it was soldered most likely broke off you can take apart and try and resolder it.
Jan 04, 2008 | Gateway M305CRV Notebook
Laptop speakers stopped working
Hello fadesit, It sounds like the headphone socket is sticking/defective. When you insert the jack into the socket a contact is broken to disable the external speakers, when you remove the jack the connection is resumed. Due to the amount of work this will take and the possibility of causing other problems in the process I would check to see if the warranty is still in effect first. If not then the next thing to ask is do you have the tools, mechanical aptitude, patience and ability to risk damaging your laptop to do this yourself? If you want to go the do it yourself route let me know and I?ll post some disassembly instructions later tonight otherwise please don?t forget to rate the posting.
Jan 17, 2007 | Dell Inspiron 700M Notebook
Acer Aspire 3680 Laptop Logo
106 people viewed this question
Brian Sullivan
Brian Sullivan
