Question about Canon PowerShot Pro1 Digital Camera
Powershot pro1 viewfinder show blank white
My viewfinder not working simply shows blank screen ....
  • 1 more comment
  • billythewiz Jul 15, 2008
    Thanks I know that , but all I see in the viewfinder is a blank white screen
    Hi thanks
    Yes it was working .
    I bought it secondhand from ebay a few days ago.
    It looks well looked after and came with the original box etc and invoice ,originally purchased 2006 july
    I was fiddling with the iso and white balance when it happened.
    Thanks
    Billy
  • billythewiz Jul 16, 2008
    Hi
    The Camera is working and takes good pictures , the LCD stil works , it is just the digital veiwfinder that doesnt work.
    Regards
    Billy
    Scholar:
  • 51 Answers
Hi
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Posted on Jul 15, 2008
  • 1 more comment
  • Glenn Upton-Fletcher Jul 15, 2008
    Hi
    I presume you have had this working properly in the past. How old is the camera itself? What was the last thing you did with the camera before this problem started?
    Regards
  • Glenn Upton-Fletcher Jul 16, 2008
    Hi
    From what i gather it is just the screen. Would this be correct? If it still powers on have you tried to take any photos with it? Is so have you transfeered thenm to your computer, and what are the results like?
    Regards
  • Glenn Upton-Fletcher Jul 17, 2008
    Hi
    Well, from what i can tell the ability to chnage from the LCD to the viewfinder should be as suggested earlier, and it seems you have tried this as well. I may have to concede that it may be in need of attention from an Authourised dealer.
    Regards
Play back screen does not show any image it is just showing a blank white back ground
A component called CCD IMAGER is faulty and needs replacement, Basically the component works as an eye to view the image when it start malfunctioning screen and viewfinder does not show image. The detail of said part is given below:
Part No. Description
8-753-244-71 ICX611NKF-13 (CCD IMAGER)(HC51E/HC52E/HC53E/HC54E)
For convenience area is marked with red circle in the picture below:
Thanks
May 19, 2011 | Sony DCR-HC52E Mini DV Camcorder
My Canon Powershot Pro1 will not accept the memory card. The screen flashes "Memory Card Error" every time I turn it on.
Your camera uses a Compact Flash card so it's asking you to format the card.
Here is a diagram to show you were to go and the process for formatting the memory card
Diagram
I had one tough time finding a DPF manual for this camera. Looks like a feature rich camera cheers have fun
Jan 17, 2011 | Canon PowerShot Pro1 Digital Camera
I own a canon PowerShot S51S. When I open the camera to take a picture , it is blurred. But when I download to my pc or look them after in the camera it's O.K. Any help would be appreciate.. Lise
I'm not totally sure of your question or concern but let me attempt to show some light on what it is I think you are asking. The Canon PowerShot S51S is a huge step up from a pocket point and shooter, this is a very powerful camera with features that would make some Pro camera whimper. So to the problem I think you are having. The camera is fitted with an optical viewfinder but the image you are seeing isn't "Through the lens" in fact it's a digital image of what the camera sees and therefore will not appear clear to your eye. The image will look a little grainy and slightly out of focus. If the in focus indicator is showing your image is focused then take the picture as long as the focus indicator light is on then the picture will be in focus. The problem you are experiencing is compounded if you wear glasses. This is one place where you need technology to rule. I know what you are feeling believe me because I still have problems with a digital viewfinders. Right now I use seven different cameras one of them has the digital viewfinder and it just make me stop and think then rely on the in focus indicator. Hope this was a help but as long as the camera is functioning properly you have no concerns. By the way you have chosen a great camera for creative photography. Happy Holidays from Robert in Canada
Dec 24, 2010 | Canon PowerShot S51S Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Buttons don't work
Hi
Have you turned the mode lever to the point at the setting that looks like a little camera, some thing like [O].
Try This:
1. Turn the Mode lever to [O]
2. Press the function button. (Found to the left of the eyepiece/viewfinder)
3. Use the up and down buttons to get to the setting you want to change (found on the dial to the next to the LCD screen).
4. When you get to the setting you want to change use the right arrow to enter and make the change use the left to go back to the main menu.
Hope that helps.
Jul 05, 2008 | Canon PowerShot Pro1 Digital Camera
My viewfinder does not work
Sounds like your LCD is cracked. You can get it replaced for $89.95 at darntoothysam.com.
Mar 08, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
LCD display works only in one particular angle and goes white in other angles
check the connections on the swivel arm. make sure all the wires / connectors are good
Dec 27, 2007 | Canon PowerShot S3 IS Digital Camera
Canon powershot pro1 will not turn on
You have to try another battery to know for sure if it is bad. I have three batteries so that I can rotate while I am working with the camera.
Jerry G.
Nov 15, 2007 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
351 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
