Question about HP Compaq nx6110 PC Laptop
Booting its booting only when i lift the one side up and press the on the other side of the laptop ,it runs and works fine otherwisw it won ,t work tell me the solutions for this
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
Check for battery loose contacts,if it is warranty contact the vendor otherwise give for service point ,its the hardware or power supply problem
Posted on Jul 15, 2008
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
Nov 20, 2013 | Dell XPS M1530 Laptop
Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Mar 05, 2013 | Dell Latitude D600 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
OnBoard USB Ports Not Working and No PS/2 Ports!
When you boot the machine does it tell you what key to hit to get into the BIOS or System Setup? If so, press it. Maybe you need to try another keyboard if it won't allow you to press a key to get into the Bios or System Setup.
Apr 21, 2012 | Dell XPS 400 PC Desktop
HP dv6-2110 won't boot up- 'Hard disk does not exist' I've had my lap top for just over a year. Its been working great! Was fine all sunday morning, then when i came to turn it on to use...
If the battery of the HP laptop is not in a good condition, sometimes booting problems might happen. To remove any static charges accumulated in the battery, you would have to remove the battery and press the Power button for about 25-35 seconds. Then reset the battery. Even after this, if your laptop is not booting up then you could perform the battery calibration and press F8 key to boot in safe mode.
Jul 27, 2011 | HP Pavilion dv6000z Notebook
My laptop wont go on to the desktop. It keeps telling something about launch start up repair but that aint working
There might be errors in the Windows Opeating System. This might have been caused by the recent hardware and software changes done to the PC. Try booting the computer into "Safe Mode", to do this, turn the pc on and while the computer starts up or right after you press the on button start tapping the "F8" key on your keyboard repeatedly until you see the "Windows Advanced Boot Options". From there select "Safe Mode" then press enter. If the computer boots into Safe Mode, you can try running a "System Restore" to restore the computer back to a date when it was working fine. Safe Mode can be accessed from Start>All Programs>Accessories>System Tools>System Restore. Follow the on screen instructions.
Hope this help. Goodluck!
Mar 27, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a Compaq CQ50 laptop, there seems to be a short or bad connection somewhere just under the power button or keyboard. I say this because the power button is not working, I press the botton and...
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Spyware
If you can get the unit to boot windows you should get and run a program called combofix, if you google it you will find it at majorgeeks website. This will get rid of those programs. If you press F8 before windows tries to load you will be greeted by a boot list, you should try last known working configuration and again run combofix.
Feb 12, 2008 | Acer Aspire 5100 Notebook
Acer Battery Power
may be this is an attack by some harmful viruses . i too experienced blue screens due to virus attack . downlaod avast proffesionl edition and install it (latest version availabel on katz.cd ) and scan computer at boot time ( avast only provides boot up scan ). otherwisw think of installing a fresh copy
Dec 03, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
HP Compaq nx6110 PC Laptop Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
