1997 Chevrolet Cavalier Logo
Posted on Jan 17, 2011
ANTI THEIFT SYSTEM CAUSES CAR TO SHUT OFF AND WONT STAY RUNNING
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
148
Points
I bought my 97 cavalier a few months ago, had the same problem. Mine had a push start, i had to turn it over and then hit the push start. I took it in to the dealership to have the push start removed, and they told me there is a recall on that year for the ignition. They took the push start out and fixed the ignition for free. Hope this helps
Does all. Factory anti theift systems on a 2004 ford explorer. Have a valet reset button under stirring column.
There are no reset buttons for a factory security system.
I would start buy checking for fuel pressure and spark. There will be a test port for fuel pressure on the fuel rail. you should see around 35 psi. If there is none than check for power to the fuel pump. I suspect you will find a fuel issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Car 2005 toyota wont start alarm light is blinkin.
ur anti theift system is on try unhooking the battery
My mini 2008 have a CD stock in. How do I take it out? Thank you Gillis
WARNING: DO NOT EVEN ATTEMP TO REMOVE THE CD PLAYER IF STOCK AS THE ANTI THEFT RUNS THREW THE RAIDO And yOU WILL TRIGER THE ANTI THEIFT ON THE CAR AND IT WILL NOT START. you have to use a computer hooked to your on board computer to stop the anti-theift from being set off then you need to buy a relay to by pass the alarm system
On my monte carlo ignition broke i replaced it now the car wont start it has an anti theift do i need to reset it ? How do i do that?
The system MUST be reset by the dealer. They have to download info into the theft system module. No way around it. They use a handheld unit called a Tech 2 which, after you download the vehicles info, has to hooked to another computer mainframe, then info is downloaded to that and then taken back to the car. There is no bypass.
1helpful
2answers
1997 Ford Expedition wont start and anti theft light is blinking. help thankyou
If the theft light is blinking very fast it does not recognize the key, will have to go to a ford dealer
Car wont start. turns over but wont stay running . attempted to install a remote starter on my 03 malibu. the first module broke so i had to order a replacement, during which time i simply left the wires...
your cars antitheft system is trying to prevent the car from being stolen so it is shutting it offf after it starts. go back over step by step you installation instructions make sure the ring around the ignition that comes with the remote starter is taped into the exact loacation it needs to be, or the cars own anti theft system will not notice it and will try to shut car off. its an anti theft feature. if this doesn't wotk you will not be able to use this remote starter. i ran into the same problem finally got it to work poperly.
2answers
98 chevy cavalier cranks but wont start changed fuel pump,computer,crank shaft position sensor and the theft system light is staying on
try to start the car, than the anti theift would shut the car off. you wait ten min with the key on, until you see the anti theift flash or disapear. than turn key to off position and try to start it. this will reprogram the computer.. Good luck.
you can also try disconnecting the battery for 30 minutes
1helpful
Battery
YOUR CAR IS EQUIPTED WITH AN ANTI-THEIFT DEVICE
MOST CHRYSLERS WILL RESET IF YOU CLOSE ALL DOORS ,LOCK CAR FROM DRIVERS SIDE "WITH KEY"TAKE KET OUT THEN PUT KEY BACK IN AND UNLOCK IT
THIS SHOULD RESET YOUR ANTI-THEIFT
TRY TO START CAR AGAIN
6helpful
3answers
2002 malibu anti theft problem
With the car RUNNING cut the yellow wire to the ignition switch from the group of three wires.
Make sure the car is RUNNING when the wire is cut.
Tape the ends and thats it.....the car will start first time from now on....as long as you don't mind not having anti theft.
Expedition anti theift system
THere are little boxes sold for remote starting on car alarms that you put a key into that will bypass the the anti- theift system
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
