Question about Bosch Dishwashers
BOSCH DISHWASHER: ON/OFF BUTTON DOES NOT LIGHT THE DISPLAY, dishwasher doesn't work
Hello! When I loaded my dishwasher this morning and pressed the on/off button, the LCD display -- which normally shows 130mins -- remained black. There was no reaction, no engine, no pump. Dead. I checked the mains plug fuse; it was alright. I now remember that for the past several weeks the warning light "salt" would light up. But since I had no salt at home and kept forgetting to buy it, I reckoned that the salt contained in the multi-layered tablets was enough. Was I wrong? Could the lack of salt have triggered a power cut in the machine? If this is a possibility, I will set off for the shops and buy some salt. But it just doesn't make any sense to me.
The dishwasher isd BOSCH EXXCEL MAXX FREEDOM PERFORMANCE
No SGS45EO2GB/56 TYPE S9G1B
Many thanks in advance
Alexander Schlichter
my email: sashasch@hotmail.com
tel: +44 7971 909 549
Loose wire in plug. fixed
Posted on Jul 16, 2008
Lg flatron 192ws ....... when i power on the display, it shows the display for 2-3 seconds and then goes off, and the power led still remain lid. i press the power button to turn off the power led and...
Possible causes of "2 seconds to black" can be
a) bad caps
b) bad ccfls and/or ccfl wiring
c) bad inverter transformer
d) bad ccfl sense circuitry
All are discussed in more detail starting with post #13 and #14 at
http://www.badcaps.net/forum/showthread.php?t=10419
Also look here. https://www.badcaps.net/forum/showthread.php?t=14144
Nov 01, 2017 | LG L192WS LCD Monitor
Toshiba 23HLV87 HDTV
Please try to unplug the TV from the wall outlet and then rest it for a while pulg it again and test. if still the issues remain then try to see the all the switch menu infront of the TV maybe lock or got errors.
melnavz
Jul 23, 2008 | Toshiba 23HLV87 23 in. LCD Television
I have canon sd 750. its lcd gets black. Shows pictures etc but view finder remains dark. display is zz. what to do?
Look for DISP or DISPLAY button in the lower-right corner of the back of your camera. Press this once while the camera is turned on. The DISPLAY button manually turns the screen on and off. This is to save battery power for extended use. You would then use the optical viewfinder in its place.
Oct 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
The oven works but the display remains blank when oven is not in use. If we press on the clock button, the time shows but then goes black again.
You just need a new oven control! It is simple to replace. Just give us a call with your brand and model number and we'll get the correct part out to you first thing in the morning! We look forward to working with you!
Oct 18, 2009 | Ovens
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have to press the power button 4 times on my monitor before it works
well i think there is problem with ur screen on/off switch and its technical problem just take it to the service centre. and u might wanna check the power cables before that it could be loose and ur signal cable to.make sure its hooked with ur system tightly .pleasure helping u .
Oct 24, 2008 | Dell E153FP 15" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
1,656 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
