Minidump problem, windows crash playing divx. msvcr80dll problem
  • 3 Answers
Software corrupted..reinstall mayb can help...
Posted on Jul 15, 2008
What is wrong with my computer? Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional information about the problem: BCCode: 19 ...
hello
you're experiencing a hardware crash caused by insufficient cooling perhaps.
C:\Windows\Minidump are always hardware problems in absence of very specific reasons to think otherwise. check your memory module(s) -- they may be the cause, especially if you're overclocking the CPU -- that's a bad idea if you are . If the machine is insufficiently cooled, that could cause problems under load - such as when you're playing graphically intensive games.
are you running on AMD CPU ? -- if so , it could have insufficient cooling (ie: heatsink and fan , try applying thermal grease on heatsink.
go to this link and review some of the blog information -- i think you have a CPU and/or memory module issue.
http://usasma.typepad.com/blog/
i hope this helps you
Nov 25, 2010 | Computers & Internet
Tip
How to View Windows Minidump Files
First of all, you need to configure Windows to save these important log files. Most of the time, this is already done automatically, however follow these steps to make sure these log files are being saved.
1) Click on Start
2) Right-click on My Computer
3) Click on Properties
4) In Windows XP , click on the Advanced tab. In Windows Vista , click on the Advanced System Systems option on the left side of the screen.
5) Under Startup and Recovery, Click on the Setting button
6) Under the System Failure section, you'll see the options for the memory dump file. Write an event to the system log should be checked along with Send an Administrative Alert. The debugging information should be set to the Small Memory dump (64K) and generally the Small Dump Directory is set to %SystemRoot%\Minidump. In most cases this is the C:\Windows\Minidump directory.
As far as the third check box is concerned, if this is checked the computer will automatically restart when a blue screen error message is encountered. So, if your computer is booting into Windows, then rebooting automatically most likely you are getting some sort of blue screen error message and its forcing the computer to restart. If you uncheck this box, then the message itself will appear so you can retrieve important details about the error.
Download and Installing the Debugging Tools to Read Minidump Files
In order to view the Minidump files, you have to download the following tools.
Debugging Tools for Windows including WinDbg
Although most of the time its not necessary, you can download the Symbol packages as well as the Debugging Tools so you can read the Minidump logs easier. Once you've downloaded the Debugging Tools for the correct version of Windows and installed them, open the WinDbg program by following these steps.
1) Click on Start
2) Click on All Programs
3) Click on Debugging Tools for Windows group
4) Click on WinDbg to open
The screen should look similar to the one below.
Deciphering the Minidump Files
In the WinDbg program, click on File, then click on Open Crash Dump
Browse to the following directory on your hard drive and open a minidump log. The drive letter will be whichever drive you installed Windows on. In most cases, this is drive C.
C:\Windows\Minidump
After you open a minidump file in WinDbg, scroll to the bottom of the file. You should see a line that says Probably caused by:, followed by a filename. This is the problem file. In my case the file was related to the ELock Program in the Acer Empowering Technology set of tools. I simply uninstalled this program from the computer and the blue screen and problem went away.
Probably caused by : eLock2FSCTLDriver.sys ( eLock2FSCTLDriver+11332 )
Although you may not recognize the file that is causing the problem, it definitely helps in tracking down a solution for the blue screen error message and resolving the issues.
on Jun 25, 2010 | Computers & Internet
Boots up crashes 3-4 times starts working then crashes after several minutes. Have replaced cpu & processor
If the CPU is working then I would put this down to either a corrupt windows installation or faulty RAM. It could also be a fault due to heat, but if you have that in check then I think it's the Windows install or RAM.
To test the Windows install, power on your PC with all hard drives disconnected, power included and if it is stable on the screen that says NTLDR is missing or insert system disk then this confirms the windows installation is corrupted.
damnor01
Nov 15, 2010 | ASUS K8V-SE Deluxe Motherboard
When I start my computer a blue screen pops up then it crashes. It has text on it but I don't get a chance to read it.
download Microsoft Debugging tool here
just select the version of your computer (OS and if it is 32bit or 64)
install it.
then check this link on how to use the windows debugging tool
click here
Every time that there is a blue screen error or a stop error, windows generates a dump file that has the details about the crash error. the dump file is located in this folder
C:\windows\minidump
you have to run the debugger, click on file, select ran deugger for crash error then after that browse to that folder and lod the minidump file.
in order for you to fully understand how to user the windows debugger, you have to read the link that i posted above.
the result of debugging will give you a detailed analysis on the problem, it could be driver issue, or the device or the OS itself
Sep 14, 2010 | HP Pavilion zd8000 Notebook
Philips HTS 3565 system doesn't play MPEG-4(.mp4) formate. TV screen doesn't show the mp4 file, but DIVX files are readable. Can u help me to solve the problem.
HTS 3565 this model does not supports the MPEG4 video format, but you can play MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra, WMV all these formats.
Mar 26, 2009 | Philips HTS-3565 Theater System
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
My computer dont want to play a dvd movie. my computer use to play dvd movies but know it dont want to play. please help me
Dvd movies required codecs according to different format so try to download divx codec which is very good and commonly used from www.divx.com and its free or click here http://www.divx.com/divx/windows/download/index.php
run it and enjoy
Aug 12, 2008 | Computers & Internet
No DVD picture
Are you able to try the Divx program? It works great for me.
Jun 27, 2008 | Computers & Internet
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Computers & Internet Logo
David Payne
David Payne
