Question about Samsung Washing Machines
I have a Samsung SW60ASP toploader and it continues to deposit black 'bits' in the washing machine after use, staining clothes and I have to wash everything again. I have had the drum cleaned, but the problem continues to recur. Please advise what you thin the problem may be. Thankyou
To overcome the problem, try using hand hot water for your wash once or twice each month, the hot water keeps the inside of the machine clean by not allowing the oily residue from body oils that adhere to your clothes from sticking to the hose etc, also there is always some water left over in the bottom of the bowl (you can't see this water) which has left over scum that has not rinsed away still sitting in this water. GIVE YOUR WASH AN EXTRA DEEP RINSE WHEN THE CYCLE FINISHES.(just turn your dial to where it says RINSE) that way your clothes will be much cleaner and the washer will have removed any left over gung etc from your clothes and bowl etc.. Hope this helps..
Posted on Aug 19, 2008
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
My LG Fuzzy Logic WF T653A machine deposits little black unknown deposits on my clothes after every 2nd or 3rd wash, they look like little bits of black wet paper ?? some-one said to change the lint bags,...
Its called scrud.
Solution is to use a couple of quantum dishwasher tablets on a hot empty heavy wash.
Doing this on advice from an LG rep. May need to repeat it 3 times.
Brendan
Mar 24, 2013 | Washing Machines
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Washing machine makes clothes get black stains Kenmore front loading Heavy Duty 2 way tumble machine.
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2009 | Kenmore Elite 45986 Front Load Washer
A few clothing items have come out of the dryer with black stains on them - looks like grease. It happens a lot with sheets. I'm guessing it happens in the wash, but I'm not sure - it couldbe the dryer...
how old is the machine... 9 times out of 10 when there is grease deposits, the tranny is starting to go, and throwing grease in the machine. Happens with all washers near the end of their life.
Jul 30, 2009 | Kenmore Washing Machines
Maytag Washer - Discoloration on Clothes
hi, i think your stains are grease from a failing drum bearing, it is a common problem, the bearing needs to be changed, hope this helps, thanks for using fixya
Feb 15, 2009 | Washing Machines
Hoover 800 RL toploading washing machine
if you use liquid fabric softner that is what it is sort of looks like grease what happens is that softner gunks up and gets up under the agitator then when your lighter clothes are washing it shows up you need to take some stuff called washer magic and just follow the directions on the bottle
Jan 01, 2009 | Washing Machines
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Stains on clothes
Have you tried Calgon to get rid of limescale deposits? Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
Sep 16, 2006 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
559 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
