Question about Panasonic PanaFax UF-8000 Laser Fax
I have a Panasonic uf-4100 that is printing,sending and receiving with a thick black line down the middle
  • 1 more comment
  • Anonymous Jul 31, 2008
    We have cleaned the rollers but when we send a fax a large black line appears on the paper.
  • Anonymous Aug 06, 2008
    I have the same problem with my canon mp 780! A thick line across the document when I receive fax. No one knows what is it? I tried cleaning, doesnt help.
    Whats interesting though, when printing a document from PC everything is fine, so its just a fax problem.
  • Peter Refaat
    Peter Refaat Sep 13, 2012
    this problem may be in the (1) laser unit or (2)drum unit
    Sergeant:
  • 284 Answers
Try to do a internal printout first ( function-6-4-start ) if there is still a problem then it sounds like you need to replace the drum take the drum out pull the flap back and look at it
Posted on Sep 10, 2008
We have a Panasonic UF-4100 and i am having problems faxing, it comes up with NO REC.PAPER 010
Posted on Aug 15, 2008
Thick black lines (of toner down each side of printed page
There are problem in your toner, in toner there is a drum which are scratched, you have to replace this drum.
Problem will be resolve.
Regards
Ashly
Feb 02, 2010 | Samsung SCX-4100 All-In-One Laser Printer
How can you clear the memory in a Panasonic UF 4100? There is a message of over 50 pages that is just a thick black line throught the middle of the sheet, we just want to clear the memory to get rid of it....
if the memory has not cleared it self by now...try this
Remove the paper
Press
Function
7
monitor key slowly 4 times
* (star key)
6
scroll down to ALL JOB CLEAR
set
wait for the machine to initialize.
Nov 04, 2009 | Panasonic Office Equipment & Supplies
Brother Intellifax 4100 horizontal lines
This is an indication the scanner is dirty. Try cleaning the scanner. There are products that have cleaner in them where you simply have to send the treated paper through the scanner.
Aug 20, 2009 | Office Equipment & Supplies
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
4100 when I copy I get a black line down the middle Ok after cleaning inside top cover, but,comes back after a few copies. Printing and sending fax ok.
Try printing out a report. If the line is still there you need to use the wire cleaner on your print cartridge or if that doesn't work, replace the drum unit.
Apr 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Turning off receive on UF-490
Press these buttons.
Function
74
set
15
set
1 for tel
set
stop
Jan 06, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
WE HAVE A PANASONIC FAX MACHINE MODEL UF-4100 AND WHEN I AM TRYING TO COPY A DOCUMANT ON IT THE DOCUMENT PRINT COMPLETLEY BLACK?
ok no prblem check your scanner if it is dirty just clean scanner.dirty scanner may cause black copy .or scanner is dead replace it with a new one.by mian jee
Dec 11, 2008 | Office Equipment & Supplies
PANAFAX UF-585
Bad fax stuck in memory. Press:
Fuction
7
6
set
Nov 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Thick Black Line Down Middle of TV
does this only occur with one input and/or does it occur when using HDMI/component cables.
if so, try getting a new HDMI cable. I have the same problem with PS3...and im about to order a new HDMI cable.
Sep 30, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PanaFax UF-8000 Laser Fax Logo
435 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
