Question about Archos AV 500 Digital Media Player
Archos av500 boot failure
I can't get past the blue startup screen on the av500, any solutions?
  • Anthony Hallal Jul 16, 2008
    Don't have any warranty
I have an ARCHOS AV 500
The player seems to be fine but i guess its the hard drive....cause it wont olay any of the selection and the words are all in a gibrish type.....please help
Posted on Jul 03, 2012
I had a similar problem... try holdin the off button long so it turns off..
then switch it on again.. it will stay on the blue screen.. ull hear quiet cliks from inside it and the red light on the left flashing.. that is the device loading the harddrive.. after a minute or so it should load up.. if it doestnt work then u may hav a problem...
Posted on Aug 08, 2008
    Master:
  • 497 Answers
Its a HDD or OS failure
Posted on Jul 16, 2008
  • 1 more comment
  • Yaz  S
    Yaz S Jul 16, 2008
    ull have to ask the company for a replacement if its under the warranty period
  • Yaz  S
    Yaz S Jul 16, 2008
    make sure to register ur device on the Archos website to get a 'Technical Support Passcode.'call Archos to tell them ur problem and if ur lucky they wud repair it free of charge
    All the best
    Thanks for using Fixya
  • Yaz  S
    Yaz S Jul 16, 2008
    but if ud like to try it ursel....i found this on a forum on the net
    ((((1. I removed all the screws, and removed the battery.
    2. Removed the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
    3. Tried to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
    4. Tried to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
    5. The best option after this would be to get a drive enclosure designed specifically for 1.8 hitachi hard disks to connect the disk directly to the computer using USB and format it.
    6. However since I didn't have a specialised enclosure, I did a lot of trail and error with the player itself (running off mains while connecting the hard disk after starting the player without releasing the power button etc etc etc) which Im sure wasnt too kind on the hard disk, but voila, I managed to start it up fine WITH the hard disk in place without the player turning off using some weird combination of holding down the power button and connecting the ribbon on the bootup screen)
    7. After this, I was able to select "format", and the player began working fine I lost all the data on the player itself, but thankfully I had backups of everything! ))))
SOURCE:
Soft ware for archos AV500
Glad to help YOU!
If I got it right you are looking for DRIVERS for your Archos AV500.
Well, HERE you have the all drivers you need.
Click on EACH ONE apart to get it (download it) or to RUN it.
GOOD LUCK!
Mar 09, 2011 | Computers & Internet
Archos Av500 startup problems
its a HDD or OS failure
if u want to try it urself...i found this one of the forums on the net..
1.remove all the screws, and remove the battery.
2. Remove the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
3. Try to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
4. Try to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
7. After this, he was able to select "format", and the player began working fine he lost all the data on the player itself, but luckily he had backups of everything!
Jul 16, 2008 | Archos AV 500 400-Hours Video Recorder
Archos AV500 30gb not booting up
Try updateing the firmware on the device
http://www.archos.com/products/video/av_500/download.html?country=global&lang=en
If you are unable to perform a firmware update on the player you will most likely have to send it in for service.
Jun 27, 2008 | Archos AV 500 Digital Media Player
Archos av500 hard drive replacement
Downgrade firmware from 1.5.12 to 1.3.12 and then replace the hard drive, it should work. It does not work with firmware versions superior to 1.3.12. If you have 1.5.13 you can downgrade to 1.5.12 using the normal archos update procedure (yes, from 1.5.13 to 1.5.12 you can freely donwgrade using standard offical method). You can find 1.5.12 firmware on the official archos download page. If you need the 1.3.12 version (not available at archos website) it can be retrieved there: http://www.opendrivers.com/freedownload/232939/archos-av500-portable-dvr-firmware-1.3.12-download.html
Jul 25, 2008 | Computers & Internet
Archos AV500 HD Replacement
I have found someone who can replace the hard drive al they will need is the serial# from the HD it also depends on the size of memory you have. They will program the HD and send it to you with the instructions ob how to install. I will post here as soon as I receive the new HD back. So Archos lied saying you cannot replace the HD yourself.I will never buy another Archos product again. I have two the AV500 and the 605 wifi which is a joke with all of the Accessories they want you to purchase.I believe they design the products to fail so you would have to purchase their new products and all of the crazt accessories to get it to do what is supposed to do in the first place.Horrible company
Jan 08, 2008 | Archos AV 500 400-Hours Video Recorder
Playing Videos on my Archos AV500
If you have windows, you can sync your videos through windows media player, when you do this it should convert the videos into wmv format, which will then play on the Archos.
Jo :-)
Jan 01, 2008 | Televison & Video
Copy Movie to my Archos Fault
Hi
I am from Portugal and i have the same problem in my Archos Av500.
Please, what can i do to resolve this problem ?
e-mail: cba_577@hotmail.com
Oct 24, 2007 | Archos AV 500 400-Hours Video Recorder
Fried Hard Drive
http://frenchyaz.com/av500.aspx
Oct 18, 2007 | Archos AV 500 400-Hours Video Recorder
Archos AV504 problem
you cannot change any thing on the AV,500GH the mechanism are built in to work on operating system 1.5.12.
Jan 12, 2007 | Archos AV 500 400-Hours Video Recorder
Archos AV 500 Digital Media Player Logo
871 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
