Changed bobbin now when i sew it locks the thread tangels what have i done wrong I have the Singer Curvey sewing machine
  • silvam_59 Jul 15, 2008
    thank you i now have a website that can answer question hoefully
  • Washing Mach... Master
  • 19,396 Answers
See if Singer website can help, if not ask for more help from experts.
Thanks
Posted on Jul 15, 2008
    Master:
  • 497 Answers
Have u rechecked the fittings?
  • Yaz  S
    Yaz S Jul 15, 2008
    bring the bobbin thread up and
    then hold both threads at the back of the work as you start to stitch. hope this works for you
    Thanks for using Fixya
    Plz do update me
  • Yaz  S
    Yaz S Jul 15, 2008
    A general rule of thumb is to adjust the top tension when having problems with the bottom thread and adjust the bobbin tension when experiencing problems with your top stitch. To adjust the bobbin tension, most machines have a small screw on the side of the bobbin casing. Turn slightly to the left to loosen bobbin thread, turn to the right to tighten.
    When beginning to sew, hold the needle thread and the bobbin thread in one hand while guiding with the other. Don't pull, but hold taut. After a couple of good stitches, you can let go of the threads. Holding these threads during take-off prevents the thread from tangling and hanging up in the machine.
    If the thread tangles in the bobbin casing during stitching, clip threads to remove fabric from under the needle. Open bobbin area and remove any loose or tangled threads. Even the tiniest piece of thread which has remained stuck in the bobbin casing can cause the machine to sew improperly. Check to see that the machine is threaded correctly and that the bobbin is inserted properly in the casing.
    you should be able to make most minor repairs on the machine without professional assistance
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
How to remove the bobbin case on singer 4411 sewing machine. Thread is accumulated under the bobbin case and the case is sin wrong position.
Hai, I think your machine time is changing. So you can't remove the bobbin case. Please go to mechanic shop. First time you look and see. Next time you can try.
Apr 01, 2014 | Singer 4411 Sewing Machine
Sewing machine not cars
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is turned the right direction in the bobbin case
if the bobbin is turned the wrong way in the bobbin case it will
cause sewing problems,,( believe me,,)
make sure the top thread has not come off the thread take up lever
Oct 15, 2012 | Singer Sewing Machines
I have a singer 20u, the bobbin always drops when i put it in , i cant sew at all.please let me know how to fix it.
it's very possible that there is something wrong with the bobbin case or the hook & hook race, only a sewing machine shop can tell you for sure what wrong with the machine
May 29, 2012 | Singer 20u Sewing Machine
Material wont feed threw bobbing gets tangeled
try rethreading the machine top & bobbin--use different thread this time
try a new needle
clean under needle plate & bobbin area for loose threads & lint
Jan 10, 2012 | Baby Lock Sewing Machines
Bobbin is tangeling thread and my singer futura machine stops and beeps. I have tried to clean the bobbin area and replace the bobbin. I think it is not in correctly because it appears to move around and i...
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
Jan 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Washing Machines Logo
Top Washing Machines Experts
