Logitech Cordless Mouse Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I use a Logitech optical cordless mouse w/ 2 computers w/1 monitor. I switch back and forth between computers with a KVM switch. In order to avoid software clashes, I have to switch the mouse's stick (?) back and forth. Can I buy another one so I don't have to do that?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 286 Answers
  • Posted on Apr 14, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
286
Questions
0
Helped
38576
Points
694
Im not sure if you can do this. But, I may have an answer for you. Why not buy an Identical mouse and stick. And set up just one mouse with both sticks... Dont know if it will work, but, its worth a try..
Let me know if it does work..Thanks.
hope this helps
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Mouse quit working
Logitech wireless mice operate in a slightly different technological sphere to wired mice.
Wireless mice need batteries, they need to be turned on and they need an interference-free radio environment.
One advantage of wireless mice is that they tend to function with laser or optical parts rather than a ball and wheels, so there are fewer moving parts to go wrong.
However, optical and laser wireless mice have considerations to take into account.
Change the batteries in the mouse if the mouse doesn't work.
Remove the battery cover and insert new batteries.
On the underside of the mouse could be plastic sticker with a phillips head screw (star) under it
Turn the Logitech wireless mouse on with the switch on the mouse.
Plug the USB receiver into a USB jack on the computer.
Try to use a free jack that's actually on the computer rather than one that's in a hub.
Test the jack first.
Try plugging in a printer and see if the printer is recognized--that way you know the USB jack is good.
USB jacks are notorious in that you frequently get a bad jack on a computer.
Turn off devices that are in the same frequency range as the mouse.
Logitech wireless mice operate at 2.4 GHz, which is in the same area as Wi-Fi routers and older cordless phones.
Start by turning those devices off and see if you can eliminate any causes of interference.
Test with wireless speakers too, then computer power supplies, monitors, cellular telephones and garage door openers.
Place the mouse on a flat surface that doesn't reflect. Avoid metal surfaces too.
Kvm switch screen resolution
Formore details please visit http://www.kvmconsolesolutions.com/
1helpful
2answers
User manual for lx6 cordless optical mouse, logitech
i have logitech LX 6 cordless optical mouse... it dont work... i put in usb that connecting mouse and then turn on (mouse). The problem is that is worked maybe 2 hours ago...and now dont... can you help???
2helpful
2answers
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
5answers
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
KVM switch use with Logitech keyboard
The Scroll Lock key on the mx3200 is Function + Pause/Break and it will toggle on a KVM but I can only get the keyboard to work not the mouse.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
