Question about Dell OptiPlex GX200 PC Desktop
Cant boot to windows
My problem sort of is quite urgent.
Anytime i attempt to boot ma computer all that i see is press F1 to reboot and F2 to enter setup utility.
I have however tried all of them but i seem not to find the solution to my problem.
because of this i am unable to get access to even windows which is the operating system that i use. please help me
URGENT.
    Genius:
  • 1,226 Answers
This problem could be either the hardware not detected. the Hard drive. or the computer CMOS battery is weak.
Ok try this. if the system wanting you to press "F2" then press " F2" then in there find " load bios setup default" and save and exit and exit the setting.
For more info about bios setting refer to your motherboard manual.
if still problem exist after then, maybe the cmos battery is weak. u can replace that and do again what is explain in above solution.
This is a partial solution tell me what happen next i will give you the soltuion.
melnavz
Posted on Jul 16, 2008
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
I forgot my 2go password and i need it urgently,pls.
am using a cellphone and i fogort my password and evrything. I want to register another account. Pls help
Sep 21, 2011 | Computers & Internet
How can i set up defaut values on my packard bell laptop
Enter the BIOS configuration, pressing F2, F10, F1 or DEL at boot. At the BIOS screen, go through the pages, there will be an option to set everything to optimized defaults, save and reboot.
Sep 08, 2011 | Intel Packard Bell R4360 Notebook
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
My dell dimensions e310 is having problems.. when i power it on it says Drive 1 not found: Serial ATA, SATA-2 Strike F1 key to continue, F2 to run setup.. When i press F1 it says NTLDR is missing... I...
1 . Insert your Windows installation CD. Reboot the computer. Your computer detects the boot media in your drive and asks you to press any key to boot to the Windows installation disk. Press the space bar on your keyboard. A blue installation window is shown.
2 . Press the "R" key to start the Recovery Console process. Press the "1" key to open the command line console. You are prompted for the administrator password. Enter it into the console and press "Enter."
3 . Type the following text into the command line:
copy e:\i386\ntldr c:
4 . Replace "e" with the drive letter for your CD-ROM drive. This command copies the NTLDR file from your installation CD to your hard drive
5 . Remove the CD from the drive and reboot the computer again. The Windows operating system should successfully boot.
Thanks for using Fixya.
Feb 03, 2011 | Dell Dimension 4600 PC Desktop
Please tell how you install XP cuz i cant instal mine notebook same like yours Acer Aspire 5332
If you have the Windows XP install disk (and not an upgrade type) Simply enter your computers BIOS by pressing the key indicated when you first power the laptop on,(Try Delete, F1 F2) and make sure that in the boot order, the CD/DVD drive comes before the main HDD. Once you have the laptop set to boot from CD, insert the windows install disk and reboot the computer. It should say "Press any key to boot to CD/DVD....." Hit a key here, and then follow the on screen Windows installation instructions.
Jan 07, 2011 | Acer Computers & Internet
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
Jun 05, 2009 | Dell /Poweredge 6650 BackPlane 2+3 Board...
Restoring computer factory settings
another suggestion is boot the system from your OS disk, if you have one, and repair or reinstall OS. Reinstall should not cause you to loose any files.
Jan 01, 2009 | Dell Inspiron 531s Desktop Computer
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Dell OptiPlex GX200 PC Desktop Logo
Alun Cox
