Cannot get connectivity for mp3 rocket have turned fire walls off and still comming up with firewall block
    Sergeant:
    Champion:
  • 327 Answers
Ya had same problem with a few programs do not turn firewall off just allow the program through the firewall and if you have a router you have to let it through there to and windows firewall to and if you have a antivirus program same goes for it
sometimes if you run the program as admin it works to
Posted on Jul 15, 2008
MP3 Rocket 6.4.10 doesn't open on windows 8.1
I right clicked on "Free Download Now" then clicked on "save link as". Then went to that file & right clicked "open as administrator" it took me directly to the Mp3 Rocket downloader & installed fine. MP3 Rocket is the fastest MP3 converter out there love it converts...
Aug 08, 2014 | MP3 Rocket
I just installed MP3 rocket on my macbook and it wont connect to the internet, it just says "starting connection" I went into my firewall settings and allowed the connection and I have re-installed it 3...
Actually MP3 Rocket has no Mac version. I have tried to install it on my Mac OS X Yosemite but failed. I can't run it properly, even couldn't finish the installation. So I turned Any MP3 Downloader for help. It just worked well on my Mac.
http://download.cnet.com/Any-MP3-Downloader/3000-2141_4-76171793.html
Also it has an article which has introduced how to find MP3 Rocket for Mac alternatives: http://www.anymp3downloader.com/mp3-rocket-for-mac-alternatives/
Oct 01, 2013 | MP3 Rocket
I can't run my mp3 rocket because mp3 rocket got block by fyrewall.please help me
There were two ways how to unblock mp3 rocket so that it will work, it's either you will totally turn off the fire wall of your computer but I don't recommend this because it's risky or you will just Except the software from being blocked by the firewall. If you select the latter you can easily follow the procedure:
>>Control Panel >>Network Connections>>Local Area Connection >>[Right Click] Properties >>Advance >>Setting >>[Menu] Exceptions >>Programs and Services
Please check if the program is there then uncheck it. If not there then add the program by hitting the add button and look for it in your system. Follow instructions and apply it then click OK.
Mar 08, 2010 | Network Computing Devices (NSH800S/A)...
Firewall is blocking my msn and i cannot get into it
go into your computer firewall settings and click trun off fire wall. connect to msn then as you are on msn go back to the firewall settings and turn back on it should correct the problem. if you cant connect to other wesites leave ur firewalls off seems to me you have picked up a slight virus.try shutting them off first tho
Sep 13, 2009 | Microsoft MSN Messenger Connect Service
Same thing
try flshing the software it means u need to format n install new software in it it wil work....
Jul 15, 2009 | Dell Dimension 4600 PC Desktop
I cant installe yahoo messenger because of a fire wall.
Try use Yahoo Messenger 9, the latest version. Before download yahoo messenger, make sure firewall allows your connection to download it. It shows that your PC protected from any harmful software because of your firewall. One more thing download your yahoo messenger only for trustful sources websites, it much better. i think you should check your firewall settings. Check also your Windows Firewall. I think there are some problems in your firewall settings. It may be blocked your yahoo messenger from downloading it into your PC. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to install yahoo messenger,check it out, may be it blocked your yahoo messenger. I think this tips can be help you a little bit.
Good Luck!
Jun 01, 2009 | Yahoo Messenger
I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger, check it out, may be it blocked your yahoo messenger services. Check also your Windows Firewall. I thick this can be help u a little bit
Try to find out this! All the best!!
May 31, 2009 | Yahoo Messenger
Firewall blocking runescape
Disable all firewalls, as Norton, Zone alarm etc.
Also disable windows firewall from control panel.
If it still does not work check the router settings. Routers have internal firewall, you may need to add your laptop's ip or mac address to the firewall as trusted one.
An alternative is connecting laptop by wires to the router, probably the router firewall will let it go , as wired connections are set to less resticted security.
Sep 17, 2008 | Video Game Consoles & Games
Fire wall
if your routers firewall is turned on than I turn off my internets firewall. I dont know if this info will help your situation.
Dec 28, 2007 | 2wire (1000-400108-001) Router
Firewall issue?
Yes this is possible you can turn off the fire wall or you can open up the port your down loading program uses to communicate with its peers. in the menu I believe you will find a tab for port forwarding. They may even list the program you are using. in any event here is a link on port forwarding that may help: http://portforward.com/english/routers/port_forwarding/Actiontec/GT704-WGv2/BitTorrent.htm Subsittute your ports for the one on the web page and you should be connected in no time.
Sep 04, 2007 | Actiontec (GT704WG) Router
Computers & Internet Logo
David Payne
David Payne
