Question about Nokia 6630 Handheld
6630 Dear sir, i have 6630, charging but it can not full charge even the battery & charger is new & original, i try to reheat, change, the power voltage regulator I.C (tahvo) but its not work, i reheat also power I.C but again is not work... can you help me pls....thanks...
  • erdz bulosan Jul 15, 2008
    dear sir/ma'am, i have 6630 cellphone, charging but can not full charger even the battery & charger is new & original. i already try to reheat, change the power voltage regulator (tahvo) but its not work, i've try to reheat also the power I.C but is not work again... can you help me pls........ thanks....God bless and more power....
  • robinson1029 May 11, 2010
    When you try charging the phone does it show that it is charging ...
  • 49 Answers
Posted on Oct 28, 2008
Nokia coolpix p100 wont charge
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Aug 13, 2017 | Nikon COOLPIX P100 Digital Camera
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
6630 charging problem
Hi Friends,
I am Raheel Ansari from Pakistan, Karachi. My 6630 's battery is getting discharged very soon I have buy New Batteries but issue still remain. kindly help me out in this regard.
Thanks & Regards,
Raheel Ansari.
Aug 31, 2008 | Nokia 6630 Handheld
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Batery light blinking
try rundown the battery 3 times if still not holding charge your battery is faulty you have to replace it.
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
E115 Won't Hold Battery Charge
You might hook your charger up to your battery and check the voltage that you are getting when it is fully charged. It may be that the charger is bad. Your voltage when fully charged with the battery on it should be a little over the rated voltage of the battery. Just a thought. Be sure you are using the correct poweradapter/charger also. Reply With Quote
Sep 06, 2005 | Casio Cassiopeia E-115
Nokia 6630 Handheld Logo
212 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
