Question about Foxconn (945G7MA-8KS2) Motherboard
Startup fault I updated the bios of my Foxconn c51xem2aa motherboard and now it wont boot up. it stops with 29 displaying on the boot lcd. any ideas?
  • forcednative Jul 15, 2008
    any ideas on how to fix that? and how can it be windows if it doesnt even get to the OS boot stage?
  • 87 Answers
I think this probelm was related to mother board please check *********** Board and reolve that probelm
Posted on Jul 16, 2008
  • 13,433 Answers
If the bios is corrupt try hot flashing it
http://www.techarp.com/showarticle.aspx?artno=62&pgno=0
Posted on Jul 15, 2008
    Sergeant:
    Champion:
  • 417 Answers
Software Error Or Corrupted windows File files
I need to download bios updated FOXCONN G41MXE-K
hope this helps
Download Foxconn G41MXE G41MXE-K P10 motherboard BIOS ...
https://www.wimsbios.com > BIOS Updates > Foxconn
Download and update your Foxconn G41MXE G41MXE-K P10 motherboard BIOS - Foxconn_G41MXE to the latest version.
Apr 02, 2017 | Foxconn Computers & Internet
Mainboard error for install to win7 finalliting install
Hello the mainboards homepage is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000576
From here you can download a manual.
You need at least 1gb of ram to install windows
And min.1,6 ghz cpu.
Is the windows disk an original or a copy ???
If a copy it may have be burned too fast.
Burn it not more than 4x or it will skip some files
and not be able to finalise the installation
I could also be the dvd drive.
Try also to enter the bios and set it back to factory settings
remember to set up the boot option again.
You also need a sata harddrive.
An IDE drive is too slow.
First boot device dvd
And second the harddrive
Good luck
Oct 27, 2012 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
How to update BIOS on Foxconn 945 7AD Series please?
You are hitting the wrong key... You need to hit the <Del> Key. Hit the delete key several times at startup not "alt+f".
May 22, 2012 | Foxconn Computers & Internet
My new video card Sapphire HD5770 is installed and now my pc will not post or boot, what can i do?
Make sure you have your card installed correctly in your PCIe slot, it should hook in. You also have to hook up power supply. This card requires minimum 450 watt power supply and 600 watt power supply if using crossfire and dual mode. If your system meets these requirements, and you have card seated properly and hooked to power supply. You may have to enter your bios and dedicate the PCIe slot. I'm guessing the system will boot without card.
Apr 04, 2011 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Will not power down, bios code 7F,
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Aug 27, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
I have a foxconn C51XEM2AA that suddenly failed to boot up ,with no previous symptoms. About 3 days before this non startup my wife in haste got her foot caught in the mouse wire and pulled the computer...
it looks like something is loose .
open it up , take off everything , connect back everything .
ensure that everything is fully inserted and seated.
then turn on.
if nothing is damaged , it should come on.
if it comes on and shows no operating system , you need to reformat and reinstall.
good luck
Mar 14, 2008 | Computers & Internet
No boot up or bios or image after installing the new mother board, Mr Bogdan
Brand new board? Unlikely to have a problem. Are you sure you connected the small 4 pin power supply connector to the motherboard as well? (besides the main supply connector)
If you have any IDE drives make sure you have not reversed the orientation of the cable.
Regards,
Anand
Dec 17, 2007 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Foxconn (945G7MA-8KS2) Motherboard Logo
153 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
