Question about Microsoft Windows Vista Ultimate Edition
Rename user folder
I want to rename the user folder under user in vista
  • Microsoft Master
  • 19,396 Answers
You cannot rename the user folder because it is a system folder.
You can go to user accounts in control panel and rename the user account from the 'old name' to new name'. Unfortunately this will be purely cosmetic, the account will still be seen by the system with 'old name'.
The only efficient solution is going into control panel/accounts and creating an new account with 'new name'. Then you transfer all data to 'new name' account and delete the old account.
Posted on Jul 15, 2008
User profile cannot be loaded
If you have an alternate profile on the machine, you can log in with that account and then find the folder with your profile and rename add ".old" to the end of it. When you log back in it will rebuild your profile and you can retrieve your data from the broken profile.
If you cannot access the profiles folder with another user account you will have to either use a Live Linux distribution or attach the hard drive to another device.
On Windows XP user profiles are located under C:\Documents and Settings\%profilename%
In Windows Vista/7/8 they are located under C:\Users\%profilename%
Where it says %profilename% you will need to change the corrupt profile and add .old to the end of it
Dec 15, 2013 | Compaq Computers & Internet
Tip
How to rename or move a User Profile folder ?
To rename (or move) the User Profile folder, you may use the following method. This method has been adopted from KB314843, but this page explains in detail how to rename an User account home directory.
Though you can move or rename the user profile folder, there may be some side-effects after using this method. This is because of the reason that there may be some absolute path (to the old user profile folder) references in the registry, made by third-party software. Therefore, there may be a loss of functionality in some third-party software which stores the file locations as absolute paths, in the registry.
Before modifying the registry, you need to take a full backup, in case you want to Undo the changes or to recover from disasters caused by incorrect registry modifications if any. You may use ERUNT for a full registry backup. Use Registry Editor at your own risk
Rename the User Profile folder using Windows Explorer
  • Logon to an admin account that is not the account being renamed.
  • Open the Documents and Settings folder, by typing this in Start, Run dialog:
%SystemDrive%\Documents and Settings
  • The list of folders will be displayed. Select the corresponding folder of the user account that you want to rename.
Example %SystemDrive%\Documents and Settings\OldUsername
becomes
%SystemDrive%\Documents and Settings\NewUsername
Next step is to notify the registry that the folder has been renamed (or the Profile Path has been changed)
Changing the ProfileImagePath value in the registry
ProfileList key, SIDs and the ProfileImagePath value The ProfileList registry key contains some sub-keys, which are nothing but the list of User Account Security Identifiers (SID). Each of the SID represents an Account. The key is located here:
HKEY_LOCAL_MACHINE \ SOFTWARE\ Microsoft\ Windows NT \ CurrentVersion \ ProfileList
Identify the SID for your User account, and change the Profile path
  • To know the SID for your user account, you may use the script sidlist.vbs
  • Download the script and run it. (The User Account names and SIDs will be listed in a log file, and opened automatically.)
  • Note down the SID for your account.
  • Then, in the Registry Editor, select the correct SID that belongs to your user account.
  • In the right-pane, double-click the ProfileImagePath value and set the correct path and folder name. ( The ProfileImagePath stores the full path of the User account home folder. )
becomes the following:
You're done now. Close Registry Editor, and restart Windows. See if you're able to logon to that user profile successfully. Additionally, to verify if the path has been changed successfully, type SET in the Command Prompt. If you find any abnormal behavior while running an application (in case), you may Undo the above procedure. Then you may use the Copy To Profile method instead to accomplish your task.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
I deleted all my bookmarks from chrome accidently, i wish to restore all my bookmarks, i have around 2000 book marks
You should be able to see your hidden folder , so that you can see the Local settings folder.
For Xp user's, Go to : C:\Documents and Settings\Administrator\Local Settings\Application Data\Google\Chrome\User Data\Default
For Vista user's, Go to : C:\Users\Administrator\Local Settings\Application Data\Google\Chrome\User Data\Default
You can see a file named 'Bookmarks.bak' . May be you can make a backup copy of this folder for safety purpose, but it works out usually. Delete the file 'Bookmark' and rename the file 'Bookmarks.bak' to 'Bookmarks'.
Sep 25, 2013 | Dell Studio 15 Laptop
My emails have disappeared
Please verify if you have renamed/upgraded your account to Outlook.com. If yes, please be informed thatyou are only upgrading the user interface of Hotmail to the new user interface; hence all your emails should still stay in your Inbox. There could be many reasons why emails could be lost after renaming:
1. Due to inactivity in account:
If your emails were over 365 days old, you may have lost them due to inactivity in the account even before you renamed the account. If you had Self-recovery of emails turned on in your account before renamed, you can try to recover some of the deleted messages yourself, please refer: Deleted email messages.
2. You got another option to save your Hotmail emails differently when renaming your account to @Outlook.com account:
If you chose to rename your account to @Outlook.com, a prompt would have asked you - 'Where do you want to save your emails?' You will have the option to create a new folder for your old account or save the emails in the Inbox of your renamed account. If you chose to create a new folder, the default name of the folder will be the name of your old account and the folder will appear in the left pane under 'Folders'. And all your old emails will be stored in this folder.
3. Your account was hacked even before you renamed your account:
A hacker had already deleted emails in their account before you renamed the account.
Thanks!
Jan 18, 2013 | Google Gmail
The application preferences file is damaged. Please remove it and re-launch QuarkExpress [297] Where is the preferences file located? (Version 9, Windows 7)
The preferences file will be in the User\AppData folder.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 7 is the location in Vista with version 7 and it should have a similar location in Windows 7.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 9 is likely. (AppData has 3 folders - Local, Local Low and Roaming.)
You should not delete the folder. Instead rename it. Right click on the folder and select Rename. Then name it
old_QuarkXPress 9.
This could be a hidden file. If you click Start and then enter Show hidden folders. Then put the bullet on Show hidden files, folders and drives. Then click Apply and OK.
If moving the AppData location to another folder doesn't solve the problem, check if there is a Preferences file in the Program Files folder (
C:\ Program Files\ Quark\ QuarkXPress 7.x for the old version.) If the new version is built for the 64-bit OS, it might be in the x64 Program File folder. Again rename the file if it is in that directory.
I hope this helps.
May 14, 2011 | Computers & Internet
I want to get my profile back
This can be a little easier than it sounds, but it takes a quite a few steps. The profile names only get extensions like .domainname or .thiscomputer if there is already a folder in the profile folder under the username. The easiest way to recover the original profile is to log in as another username with admin rights and follow these steps:
BE CAREFUL NOT TO DELETE ANYTHING YOU NEED!!! If in doubt MOVE to a backup location instead of deleting
Remove any "new" profiles under the same username
Delete (or move) the "new" profile folders, so that there are no folders in the profile folder under the username you want
rename the profile folder of the username you want to keep - i.e. rename it to "OldUsername"
logout and log in as the username you want
logout and log back in as your alternate admin user
look in the profiles folder, you should now see a folder with the original name corresponding to the original username folder you renamed. If that folder does not exist, something is not working right - you'll need to give me more information before I can tell you what.
copy the contents (make sure you have your view settings set to show all files, including system files) from the renamed profile folder (OldUsername if you used my suggestion) to the newly created profile folder. Overwrite anything that exists in the folder.
Logout and log back in as the desired username. All settings should be restored.
These steps are dependant on continuance of profile foldernames. The "new' Profile folder MUST be the EXACT name of the original. This is because many items in the USER.DAT (user hive of the registry) point to folders by name. If you don't get the foldername correct, the process will not work.
Nov 12, 2009 | Microsoft Windows XP Professional
How to install vista themes in vista basic
First of all download Windows Vista UxTheme patch.
And follow these steps to install:
Step 1: How to install
1. Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper).
2. Navigate to %systemroot%\System32
3. Right-click uxtheme.dll and click properties.
4. Take ownership of the file and close dialogs.
5. Repeat steps 3 and 4 for themeui.dll and shsvcs.dll
6. Right-click uxtheme.dll and click properties.
7. Give yourself (or group) Full Control permissions and close dialogs.
8. Repeat steps 6 and 7 for themeui.dll and shsvcs.dll.
9. Rename uxtheme.dll to uxtheme.old.
10. Rename themeui.dll to themeui.old.
11. Rename shsvcs.dll to shsvcs.old.
12. Copy patched files into %systemroot%\System32
13. Reboot (yes, this is really required)
Step 2:
Download a Windows Vista Visual Style from our free Windows Vista Themes gallery, and copy the theme to Windows/Resources/Themes folder.
Step 3: Right click on desktop and click on Personalize. From the page that pops up, click on Theme and choose your newly installed theme! and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Yamaha FZX 750 Motorcycles
Install desktop theme
Hi there! Here's a solution to your problem. If you're using Vista WITHOUT SP1, Step 1: Download the UxTheme Patch from here. http://www.softpedia.com/get/System/OS-Enhancements/UxTheme-Patcher-for-Windows-Vista.shtml If you're using Vista WITH SP1, Step 1: Download the UxTheme Patch from here. http://www.softpedia.com/get/System/OS-Enhancements/UxTheme-Patch-for-Windows-Vista-SP1.shtml Step 2: Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper). Step 3: Navigate to %systemroot%\System32 Step 4: Right-click uxtheme.dll and click properties. Step 5: Take ownership of the file and close dialogs. Step 6: Repeat steps 3 and 4 for themeui.dll and shsvcs.dll Step 7: Right-click uxtheme.dll and click properties. Step 8: Give yourself (or group) Full Control permissions and close dialogs. Step 9: Repeat steps 6 and 7 for themeui.dll and shsvcs.dll. Step 10: Rename uxtheme.dll to uxtheme.old. Step 11: Rename themeui.dll to themeui.old. Step 12: Rename shsvcs.dll to shsvcs.old. Step 13: Copy patched files into %systemroot%\System32 Step 14: Reboot After you have applied the patch, you can copy the theme into your Windows/Resources/Themes folder!
Jun 13, 2009 | Microsoft Windows Vista Ultimate Edition
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
About installation of themes
Step 1: Download Windows Vista UxTheme patch.
How to install
13. Reboot
Step 1b: If you find the above too intimidating, download VistaGlazz and just run it, it automates the whole patching process so you don’t have to worry about it!
Step 2: Download a Windows Vista Visual Style from a free Windows Vista Themes gallery, and copy the theme to Windows/Resources/Themes folder.
Jul 13, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
117 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
