Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
How do i change the "channel" of my wireless internet?
  • flocox Dec 07, 2008
    I am having the same problem with my Belkin. My network does not show up in Available connections and the troubleshooter suggests I change the channel to 1 and reset, if that doesn't work then try 6 and reset. It is on 11 now.
    I have a Netgear WGR614v6 router.
    Thanks for any suggestions.
    Sergeant:
  • 287 Answers
The belkin USB adaptor does not appear to have a channel selection option. Like most WiFi adaptors it scans and connects to the available networks assuming the security matches.
What you need to do is change the BROADCAST channel in your router or access point. If you are unsure how to do this I suggest you post the make/model and I'll try to assist you.
Ensure you use 1-11 as this adaptor does not support ch 12 or 13 wheras some routers do.
You may find the NETSTUMBLER prorgam useful in finding a free channel to use.
Posted on Jul 15, 2008
Internet isn't working right. Say error code 51030
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Mar 20, 2011 | Nintendo Wii Console
Tip
Nintendo wii Error Code 61070 fix
Error Code 61070
  • Make sure that your Internet connection is compatible with the Wii console's online service. You must have broadband Internet (Cable, DSL, or Fiber Optic) and a compatible wireless router. For more information, click here.
  • If you have verified that you are using a compatible Internet connection, then it appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
on Sep 03, 2010 | Nintendo Wii Console
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can I change the channel selection on my router....it keeps dropping the internet signal. Is there something else I should try?
In order to change the wireless channel of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless Network Settings under which you can change the wireless channel and click on save settings at the top .
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
How can i stop my wireless internet from going out when mircowave used?
Hi Sandy,
I got your issue,
1. Open Internet explorer and in the address bar type 192.168.2.1 and hit enter
2. You will be logged into the belkin router setup,it will ask for login password, leave it blank and click on the button "submit"
3. In the left side Under wireless , click on channel and ssid
4.In the channel and ssid , change the channel:11 or 6 and click on apply changes
Then it will not kick you out of wireless internet even when your microwave is ON
Thanks & Regards,
Prema
Nov 13, 2010 | Belkin Basic Wireless Router
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
Cant get internet connection on my laptop
You need to change the wireless channel on your wireless router. Using your wired computer, open the router's setup page by going to internet explorer and type http://192.168.2.1 and press enter. It will prompt you for username and password. By default the username is admin and leave the password blank. Look for wireless tab and look for wireless channel. Change it to channel 11. Make sure to take note of the Wireless Security key as well under wireless security tab. Save the settings after changing the wireless channel. On you laptop, make sure to disable any firewall then try to reconnect to the wireles network.
Apr 25, 2009 | Belkin (F5D7231-4) Wireless Router
Change the channel
• access rtrs gateway, default is 192.168.1.1
• click on wireless tab
• wireless channel === dropw down arrow, select 11
• save settings
>>>> just make sure that while making this changes your laptop or dsktop is hardwired to any of the numbered ports of the router
Oct 23, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Cordless phones and wireless connection
you have to login to the router. Once logged in you will go to your wireless tab and and will be able to adjust the channel that the router is transmitting on.
May 31, 2008 | Linksys Wireless-N WRT150N Router
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
141 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
