Question about Fisher and Paykel GWL11 Top Load Washer
Doesn't drain My washer fills with water and washes, but won't drain. It stops at that cycle and when I try to restart it just makes a weard noise. I believe it may be the same problem that you helped mnclan with. Not sure. If so, how do I clean the filter as you suggested to mnclan? Hi, I have a Fisher & Paykel washing machine that I bought quite a few years ago. It is very reliable but just tonight it has stopped on the 'empty' cycle. There is a humming which seems like it is trying to do something but doesn't. I walked in to the laundry and the 'short rinse' button was flashing and beeping so this may be some sort of code. Can anyone help? Cheers
  • gregwh Jul 16, 2008
    THANKS HEAPS, DONE AND DUSTED!
  • 27 Answers
The drain pump is almost definitley blocked. To solve this problem properly you will need to removed the top deck of the machine, then remove the agitator and inner bowl. The opening to the pump is in the front right hand corner, using Philips screwdriver remove the pump hood and the obstruction should be accessible. Reassemble. TURN THE POWER OFF BEFORE STARTING
Posted on Jul 15, 2008
How do you get the top lid opened. My washer won't drain...
Posted on Jul 22, 2008
Do you have any instructions on how to perform this operation, in particular the removal of the top deck? I am having the same issue...
Posted on Jul 19, 2008
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
137 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
