Back to:
Tags:
Belkin 802.11a/g/b Wireless Adapter
Conection speed issue
posted by timsmith312 on Jul 15, 2008
hi, i have wireless broadband at home that should run at 54mbps, from both the router and my internal wireless card. this is in a PC desktop, not a laptop.
i have had 2 wireless cards and 1 usb card. i am not very technical, but to me this appears like it is my computer rather than network cards, or settings within my computer. i have used my father's laptop from my desk and it conects at 54mbps every time.
but my computer runs at 18mbps at the most and it usually fluctuates between 5mbps and 1mbps.
the wireless router is a BT homehub, and is only 10 metres away with only one wall in between them.
also i have had this problem in two different homes from two different routers.
i think i have narrowed this down enough to conclude it is my computer. but would apreciate any advice on how to correct this, as i have tried purchasing new cards and that hasnt helped. also i cannt afford to just go out and buy a new pc.
i look forward to hearing any advice.
thanks
Tim
please note. the selected product may not nescesaraly be the correct device ni my machine. i may be wrong.
Comment by timsmith312, posted on Jul 17, 2008
thanks for getting back to me
how would i go about checking the driver?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Agent_29805
Rank:Master Master
Rating: 84%, 10 votes
You might need to isolate your problem properly. How long have you had your wireless card for your desktop? Did you remember updating the driver of it? Do still have the cd that came with it? Is is possible to install the problem card into another pc and check if it works with the pc or still the same problem. Above all the suggestions it is best to check the driver of your adapter and try updating it.
Comment by Agent_29805, posted on Jul 18, 2008
go to device manager (right click my computer)-properties-hardware-device manager-network adapters. You will see there the wireless adapter your using.Right click-properties-driver.You will see the driver version and driver date. Ask your wireless card manufacturer if there are updates for that driver version.
Rating Locked! (?) timsmith312 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Conection speed issue:
I don't want to Accept this solution
Can you Help with these Wireless Adapters problems?
Belkin (F5D7050) 802.11a/g/b Wireless...
the first thing that pops up is the belkin, and everything...
i have had my tower rebooted and now i cannot get my...
why wont it connect to the internet? it connects to the...
i have installed the drivers and connected to my bt home...
show for me about power of ORINOCO TURBO 11Mbps Wireless...
Loading problems.
Repair Service
Find Wireless Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
