SOURCE: Mpio HD-400 is stuck on loading screen windows doesnt recognize it
No solution yet. Throw to the seller for selling such crappy gadgets.
SOURCE: I want help on this graphics card supported to Intel D845GBV
you have to give the mother board make and model
SOURCE: How I can get software to overclock intel processor
if the BIOS does not have the configurations for it, you could try getting a BIOS firmware update, or buying a new BIOS from the company. otherwise it cannot be done.b
SOURCE: URGE AYUDA PROBLEM AS CON VIDEO
hay una ocasión que el monitor está fallando… redownload e instala los conductores para esa tarjeta video… tenga muy cuidado que usted esté instalando el apropiado para la tarjeta y el sistema operativo Roberto Clasifique por favor esta solución
SOURCE: hi ,i have intel motherboard
I had a similar problem with my pc sometime ago. The main cause for this is oxidized DIMM contacts. just take out your RAM wipe its edge(The end which you insert into the slot) using an eraser and that should fix the issue. Also make sure the sound is not coming from your hard disk. If it is then just push in the power connector of the hard drive in(it has 4 pins).
Rate positively if it fixed the issue or you need more help..
