I need to increase virtual memory - Computers & Internet
  • 19,396 Answers
If you're running Windows XP, and you see a message saying "Your system is low on virtual memory. Windows is increasing the size of your virtual memory paging file.". This usually means one of the running application is a badly programmed application, and is absorbing too much memory and is the cause of the problem.
Instead increasing virtual memory paging size, you need to find out what program is giving you troubles, and eventually reinstall it.
Here is how to identify applications using memory in a bad way.
Here is info on RAM, Virtual Memory,etc.If you did not find any suspect application using a large amount of memory, then try increasing virtual memory paging size
And finally HERE is how to increase virtual memory paging size in Windows XP.
And HERE how to increase virtual memory on Vista.
Posted on Jul 15, 2008
  • Ginko
    Ginko Jul 20, 2008
    bring my rating back to normal, over 200 solutions had been voted by same person inappropriate.
    Many votes were on top of Fixya and some helpful.
    My rating was 89% before this, with 2 inappropriates and 125 Fixyas.
    Bring it back to normal
    I will report as many abuses as I can find please track the rest.
    Problem Solver:
  • 7 Answers
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
How to increase virtual memory in my windows xp pro desktop
Hi ,
Go to the link
http://www.delete-computer-history.com/increase-virtual-memory.html
and you will know how to increase virtual memory.
Thanks for using FixYa.
Jun 03, 2011 | Computers & Internet
How to increase virtual memory in windows xp pro desktop
Hi ,
Go to the link
Jun 03, 2011 | Acer Aspire 5315 Notebook
How can i free space for my virtual memory ?i don't need a solution for increasing the size of virtual memory instead i want to free space that has been occupied in the virtual memory.
Hey, You got to free space on your hard drive. The virtual memory resides on your hard drive. but if the hard drive is getting full, this will reduce the virtual memory. So make home for virtual memory by free space on your hard drive.
Apr 27, 2011 | Microsoft Windows XP Professional SP2 for...
Opening programs is so slow virtual memory running low
which operating system you are using and what is the ram capacity? and onemore thing to check what is your virtual memory capacity. for that
Right click "mycomputer" > properties > advanced >click settings on performance > in advanced tab > increase virtual memory file size.
generally its size is ram capacity * 2 (ex: for 512mb its virtual memory size is 1GB) check that and we can increase the file size also.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
CAN YOU PLEASE TELL ME HOW MUCH VIRTUAL MEMORY DOES A PATRIOT 2006 LAPTOP HAVE
Virtual memory?
Virtual memory is created and used by windows operating system.
This value can be changed and solely depends on the hard drive space available.
Simply put There isnt any limit, nor a minimum. The amount of virtual memory depends on how much was set up and can be increased or decreased at any time.
The purpose of virtual memory is to allow windows to use part of your hard drive as rams.
virtual memory and rams (conventional memory are different things)
you can have as much or as little as u need. increasing it improves performance.
So No one can actually answer that question. Simply put any amount you want is the correct answer!.
Mar 01, 2010 | Computers & Internet
The instruction at "0x012cf496" referenced memory at "0x012cf496"
you should increase the virtual memory of system,to increase the virtual memory :-
->right click on my computer goto to properties tab
->then goto advanced tab
->performance setting
->advanced tab
->virtual memory
now increase the virtual memory with current
OR
:>type chkdsk command in dos
Jan 15, 2010 | Microsoft Windows XP Professional SP2 for...
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
To speed the computer
upgrade your RAM memory ..........(better not to use different frequency RAMS this decreases the performance) refer to your motherboard manual for this......
install the good antivirus & always keep the virus away ....
so by this you can speed up your pc...
if you are using the windows xp then increase the virtual memory ...
you make the virtual memory double of your RAM size ...
you can do that by going to
control panel>system>advanced>advanced>virtual memory settings> increase the size of the virtual memory for the drive where the OS is installed ....
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | Computers & Internet
FREEZE
this happens if the rams are of different frequencies have a check with the both the ram frequency ...
if they are different then remove 1 ram ....
& try increasing the virtual memory in the OS ...
if you are using the windows xp .. then to increase the virtual memory just go to
control panel >system>advanced>advanced>virtual memory settings>increase the virtual memory for the drive in which the os is installed ....
increase nearly to the double of the ram memory you use ....
this solves your problem ..
any doubts you can reply me
thank you
bye .....
dnt forget to rate the solution ...
Jun 22, 2008 | MSI KM4M-L Motherboard
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
