Laptop7109A hi when i open my notebook there are white lines at the bottom of LCD.This area looks like a magnifier(objecuts look bigger in this area).But when i move LCD a bit forward or back wards this area becomes normal.Can u plz identify or solve the problem.
    Scholar:
  • 101 Answers
It sounds like the LCD's ribbon cable is coming loose, If you can easily remove the cover, check if the ribbon cable going to the LCD is secured properly.
Posted on Jul 15, 2008
Our Toshiba Regza LCD TV has developed a thin white vertical line down one side and a green horizontal line across the middle. The bottom half of the TV screen then comes and goes in muted and faded...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Aug 06, 2011 | Televison & Video
How can I make the letters in the words bigger? as I have a hard time reading my statements?
Internet Explorer Version 8 has a built-in "magnifier".
Look at the bottom-right of IE's window, for a magnifying-glass, a '100%' label, and a small black-coloured triangle.
Click the triangle to pick a larger value.
May 09, 2010 | Dell Dimension 3100 PC Desktop
Last night i used my laptop and it is still in good condition. I was surprised when i opened this morning, there was already a straight white line that is seen horizontally on 0.25cm from the topmost area....
It might be the problem of the LCD display wiring. Not any problems of the drivers. If your notebook is still in the warranty period, call the customer care and they should fix it.
Or else print screen, copy it to paint. If there is no white lines in the image, then sure its LCD problem. Replace the wiring with experts in case you're out of warranty period. Take care not to repair it by yourself as it could do more damage to your screen.
Apr 17, 2010 | Dell Inspiron 9100 Notebook
There is what looks to be a white & red line that goes down the screen from top to bottom
This line indicates an LCD Panel failure. There's really no other solution but to replace the LCD screen.
Sep 05, 2009 | Toshiba Satellite M35X-S114 Notebook
An area on the display it's not working. PowerBook G4
I'm sorry to say that you will have to replace the screen soon. That vertical black and white lines that appear is the early warning signs that your screen will soon go blurry, or have a partial screen, or have it just stop working. This happens from the many times the screen was lifted open and closed and the ribbon cables just need to be replaced. And since the ribbon cables can't be simply unplugged and then replaced, you will just need to get a new replacement screen.
-Luke
Dec 20, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Horizontal Lines on LCD
Make sure that you don't have windows Magnifier activated by mistake
http://www.microsoft.com/windowsxp/using/accessibility/magnifierturnon.mspx
Jul 16, 2008 | Computers & Internet
LCD screen problem
Hi Qureshi,
Unfortunately the only thing that usually fixes this is replacing the LCD. If you open it up, you will see a white strip of tape and cables on the top, back of the LCD screen. This is the most fragile part of the LCD and is most likely where the damage is. Sometimes you can find this piece by itself, but usually you can't purchase it separately.
Oct 30, 2007 | Compaq Presario X1000 Notebook
Vertical lines on my laptop screen
white vertical line on my screen of my laptop..how can i fix t
Oct 26, 2007 | Compaq Presario M2000 Notebook
Vizio 37" LCD both sides of screen seem to magnify
Repeat / press WIDE button on remote = select a different
format.............................T.
Oct 20, 2007 | Vizio L37 Television
LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
