Question about Kitchen Ranges
My oil fired aga will light then after a few hours smells fumi and starts to sut around the burner then ultimatley go out.I have had the cooker for 11 years and apart from a service every 6 months i have never had a problem.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
my oil fired aga will - small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
Posted on Jul 15, 2008
Oil fired Aga is making wheezing sound
Sounds like air passing where it should not be, try checking that all the components of the burner are seated properly for example the cap on the centre resivour and the other thing is that the wicks are high and causing a taller flame
Mar 31, 2014 | AGA Kitchen Ranges
Oil aga is not getting very hot
Hi Rich.
You might like to follow my Oil Burner servicing videos if you think the burner needs servicing.
I also sell a tool for removing the Barrel or Hot Plate AGA Hotplate Hot Plate Barrel lifter Crane
Oct 20, 2013 | AGA Kitchen Ranges
I have an oil fired aga the oil will not come throw to the burner
see the following steps:
f the burner doesn't run, set the thermostat a few degrees higher than normal to see if it comes on. If it still doesn't come on, check switches, and breakers and fuses (see the Electrical Service Panel Fix-It Guide). If the unit has a reset button, press it. Also oil the motor at any oil ports (see below). If the unit doesn't want to start and run, first check the c to make sure that the ignition is getting power. If there is power, check the built-in safety controls (see below) that may turn the system off if they perceive problems.
If the burner cycles too often, replace the filter (see below). Also, oil and adjust the blower (see the Forced-Air Distribution Fix-It Guide).
If the burner runs but won't fire, make sure the oil valves are open and that there's oil in the tank. Check the tank level with a clean stick.
If the burner smokes or squeals, shut off the unit, let it cool, and fill the oil cups. Recheck them after the motor has run for an hour.
If the chimney smokes even after the flue has warmed up, the unit is wasting fuel; call for professional repair.
Safety Controls
Oil furnaces and other heat systems include safety devices that monitor operation and turn off the unit if something goes wrong. In some cases, the safety device can be the problem.
If you encounter an operating problem with an oil furnace, first reset the safety and try again.
If the burner kicks off again, shut off all power at the electrical service panel ; the burner motor and ignition may be protected by separate fuses or breakers.
If the sensor has a photocell, wipe it with a clean rag or tissue and see if the furnace starts.
If the safety is a stack switch mounted on the flue, remove the screw holding the unit to the stack, slide it out, and wipe off the sensor.
If the furnace won't start after three tries, seek professional assistance. Unburned oil can accumulate in the combustion chamber and "flash back."
Jul 31, 2012 | Heating & Cooling
I have come down to find my aga cooker out the fire has gone out. There is oil around the burner but I can see no reason why it has gone out. Any suggestsions?
Much better than a microwave, any day!
It is quite common, if the fuel tank is not checked yearly, that condensation may build up in the fuel line and finish up with water in the fuel, causing the problem you describe. Also a sharp downdraft from the chimney can blow the pilot flame out.
Make sure it is cleaned before you re-light it. Preferably get the system serviced.
Hope this helps.
Oct 29, 2010 | Microwave Ovens
Strong smell of burning oil from chimney of rayburn
the replacement burners seems to not to be set up right. the chap should have had a analiser to make sure the settings are right.you need to call in a pro with the right kit and someone who knows how to use it. your cooker can kill when running like this do not use it
Feb 26, 2010 | Kitchen Ranges
Alpha oil fired cooker (aga type) & central heating breakdown.
you dont say but i presume you have an early model 1996-2000. these had the most horrid burners ever. its wasnt untill later when the ecoflam burners were used that problems that you describe were elimanated as a standard every day problem. better still was the much later 800 series ecoflam twin burn as fitted in the rayburn 800 series this is the aga company that closed down the alpha and now produce the same cooker with better burners.
www.topoftherangeltd.co.uk who can suply used and new burners for you
Dec 25, 2009 | Kitchen Ranges
OIL FIRED COOKER FAULT
my stanley oil fired range fires up then cuts out
Dec 15, 2009 | Kitchen Ranges
Burner propblem
have you tried to wipe off the fire eye on the unit if it has one? If it's dirty too then it will not see the flame and not let the unit come on correctly. Good Luck and have a Happy New Year.
Jan 05, 2009 | Heating & Cooling
I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have...
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Aug 01, 2008 | Heating & Cooling
Kitchen Ranges Logo
572 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
