Bushnell Velocity Speed Gun Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for free manual for bushnell sportview 4x12 scope
Kardoc
Level 3:
Top Expert:
  • Bushnell Master 7,503 Answers
  • Posted on Feb 27, 2019
Kardoc
Bushnell Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759804
Points
58323
5 Related Answers
Anonymous
  • Posted on Apr 18, 2010
SOURCE: Hi, just bought a rifle with a bushnell sportview
you'll see two horizontal crosshairs, put the top one on the animals back then zoom in until the bottom one is on his stomach. Look at the numbers on the zoom dial there should be three lines they are D - deer, E - elk and A - antelope. The numbers are the distance to the game, you then turn the external elevation knob or turret to the matching distance and shoot dead on. No need to hold over for bullet drop. The sad part will be if you didn't get the other turrets that would have come with it as they are calibrated to different calibers and bullet weights.
Anonymous
  • 63 Answers
  • Posted on Jan 05, 2009
SOURCE: scope won't sight in
Yes, rim fire scopes can't be used on a stronger firearm as the recoil will alter the internal mechanism. I fought with scopes of all types for years until I bought a used Leopold, never finding a better one! Hope you can find one of those.
Anonymous
  • Posted on Sep 05, 2009
SOURCE: i have a bushnell sportview scope on my 30/30 and
just take your scope to a gun shop that caries bushnel and they will be able to tell you the model and order in a new dial for it.if they dont have one in stock and fit it for you.
Bruce Frazier
  • 115 Answers
  • Posted on Oct 06, 2009
SOURCE: I have a Bushnell Sportview 3-7X20mm scope on a
most likely you will have to send the scope in to have this taken care of to contact bushnells customer service at 800-423-3537. press option 1. the age of the scope necessitates sending it in to have parts matched up.
bigcass
Josh
  • 35 Answers
  • Posted on Oct 16, 2009
SOURCE: just bought a marlin 336 rifle (used) with a
Here ya go. link to the users manual.
If for some reason the link doesn't work, go to Bushells site and you will find the link to get a user Manual for this scope. hope this Helps.
LINK
4helpful
Manual bushnell sportview 3x-9x.32 scope
The Winchester 94 ejects the spent cartridge straight up and out of the top of thr receiver. This nesesitates mounting a scope off to the side to avoid jamming the action with a spent case hitting the scope and failing to clear the action.
1helpful
I have a bushnell sportview 45 3.5-x10x45 WA brand new in a box what is the value
The scopes are fairly cheap, I think it retails for $140, that was a few years ago. But not much more than that. It is not a quality scope, more of a utility scope. Hope this helps.
3helpful
Sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Hope this helps, Mark the Gunsmith
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
1helpful
2answers
I have a Bushnell Sportview 4-12x40 on my rifle
I just took my Sportview 3-9x50 scope apart for same problem. Found that the groove that phillips screw rides in got compressed somehow. With a little prying, I was able to open it back up. THIS IS NOT THE ADVISED WAY TO CORRECT!!!!! Bushnell has a lifetime on this product and will gladly help you. I just f*&^ed my warranty out the window, but need scope Nov. 7 for opening weekend with my daughter!! Good hunting, Pete
1helpful
Just bought a marlin 336 rifle (used) with a Bushnell Sportview scope mounted. How can I get a users manual for it? I'm not even sure what size it is( 4-32? ) how do I adjust it? what is the knurled ring...
LINK
I have a bushnell sportview scope on my 30/30 and the top adjustment dial has come off and lost.the only info on the scope is on the underside of the scope (faded,looks like #4???,under that waterproof...
I need help with adjusting my rilfe scope after it was shook up in a fall.
Contact Bushnell and see what they recommend you do. They're pretty good about helping people out and may service it for free for you. Give it a shot.
Top Bushnell Baseball & Softball Experts
Kardoc
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Bushnell Baseball and Softball Expert? Answer questions, earn points and help others
