Question about HP LaserJet 1010 Printer
Red light keeps blinking
The red light next to the triangle keep sblinking! wat to do????
  • lynne_rigby Sep 23, 2008
    just changed printer ink and now red triangle keeps flashing and printer will not print
  • spprakash200 Nov 28, 2008
    the red light is continiously glowing remaining two green light is continiously bliknking the printer is HP 1010
    Master:
  • 479 Answers
Either the piece of paper is jammed in between the gears of the printer.
or the toner cartridge is not fitted properly.
or any of the paper sensors are broken internally.they r very delicate and very thin and r black in colour.
just connect it to the pc and give a printout and the screen will display the problem in the printer if its paper jam then cleaning is required or the sensor is broken.if it says missing cartridge then cartridge not fitted properly.
Posted on Oct 01, 2008
I have a red signal light that keeps blinking in gp328 any ideas?
A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
Best regards.
Sep 17, 2014 | Radio Communications
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Ccap light blinks once dark screen
reset CMOS then BIOS then BIOS upgrade
Nov 14, 2012 | HP Pavilion dv7-1245dx Notebook
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
2008 RS 125: red triangle light keeps coming on under accelerat...
Hi, Anonymous it's probably just a loose connection for temperature warning light and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2008 Aprilia Rs 125
May 18, 2010 | 2008 Aprilia RS 125
My nintendo keeps reseting its self wat do i do to fix
How To Disable The NES Lockout Chip/How To Fix The NES Blinking Red Light Problem. Youtube.com might be the last solution to the problem then the red flashing light of death.
Oct 11, 2009 | Nintendo NES Console
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP LaserJet 1010 Printer Logo
266 people viewed this question
Ben Johnson
