Buy a used camera (sold for parts, with good LCD) through ebay.com. If you try to buy the LCD by itself, usually it is expensive. A camera can be bought for under $15. Buy a jewellers screwdriver set for $1 from Dollar store.
Look at the following web sites to get an idea how to replace LCD.
http://www.myfixtips.com/blog/digital-camera/how-to-replace-lcd-screen-on-canon-sd870is-215.htm
Try your luck.
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Get
online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before
Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for a place to enter your serial number for
specifications. You might have to start with the Warranty area to find
it.
To
take the lcd screen apart is fairly simple. You would start by
removing the plastic or rubber bumpers that are located on the plastic
strip that goes around the lcd screen. Remove them with a real small
flat head screw driver or an pin and then you will see the screws that
hold it in place. remove the screws, remove the plastic strip by prying
it apart with a little force and it will snap out. Then start removing
the screws that hold the lcd screen to the brackets on the sides. Once
you remove them, tilt the lcd screen forward and the screen will fall
out into your hand. Use your hand to catch it because you don't want it
to fall down on the keyboard or fall out too far because there is a
cable on the back of it that you don't want to damage. You can remove
the cable from the back of the lcd. Sometimes it might be secured with a
piece of tape, so remove the tape to remove the cable.
If
the lcd does not come out once you remove the screws from the side
brackets then you might have to remove screws from the 4 corners that is
holding it.
Below are some links to the screens.
http://www.ebay.com/itm/ACER-ASPIRE-5738G-744G50MN-15-6-LED-LCD-Screen-left-connector-/110788395603?pt=US_Laptop_Screens_LCD_Panels&hash=item19cb80c253
