Question about Cell Phones
My mda vario back light keeps going off and the only way i can get it back on is to turn the phone off and back on again
    Problem Solver:
I found a website that deals with mda vario phones
Forum.xda-developers.com
Posted on Jul 16, 2008
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
The screen lights up when i switch on my mda vairo but does not show the normal screen to allow you to use the phone
hey u are having problem with with display and kit connector...... u have to change it..... go to nearest customer care.......it wll cost u very low
Mar 19, 2010 | T-Mobile MDA Vario II 1000 Smartphone
My phone the MDA Vario wont installm on my windows
download activesync
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Dec 04, 2009 | T-Mobile MDA Vario Smartphone
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
May 13, 2009 | T-Mobile MDA Vario Smartphone
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
Aug 16, 2008 | T-Mobile MDA Vario Smartphone
Will receive emails but not send them
I have exactly the same problem; phoned t-mobile; it's a problem at their end, they are hoping to resolve shortly
Jun 10, 2008 | T-Mobile MDA Vario Smartphone
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
