MY L.G TV IS NOT WORKING
Since yesterday my L.G tv is making a kind of beep sound, the power is on but when i am switching it on with the remote it is not getting swithed on , on contrary it is producing a constant on and off beep sound. tell me what to do. is there any service center in vizag?
  • 97 Answers
Try turning it on by the power after you pull the plug and put it back in. press the channell up button to see if it will turn n, if it still makes this sound locate the personyou bought it from and let them know. hope you sill have warranty.
Posted on Jul 15, 2008
Remote don't work
turn on am radio and tune to higher end of the dial and push the buttons on the remote and listen for beeps through the radio if beeps are there then the remote is putting out some kind of signal but i would change batteries also make sure nothing has been spilted into the remote if so it must be cleaned with alcohol and try again on tv
Feb 22, 2013 | Emerson EWF2004 20" TV
In my BPL Make big Colour TV with picture tube, remote control light is now glowing, i am getting a beep beep sound, not able to switch on tv.
If the light on the remote is always on remove the batteries, you may have a stuck button on the remote--with batteries removed try to operate manually.
Dec 22, 2012 | Televison & Video
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
We have an AK59-00104R remote for our Blu-Ray player and a Samsung TV. The remote has been working fine on both for over a month now and yesterday it stopped working for the TV. I'm thinking my 1 year old...
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Jan 25, 2011 | Samsung AK59-00104R Remote Control
We just bought a ps3 yesterday, it worked last night to watch a movie and then we got a new tv today and it gives audio but no video.
It sounds like since you need to try resetting the video settings. When switching between HDMI and AV or changing TVs, you can get a blank screen. Try these steps to reset it:
1. Make sure console is turned off completely(red light in front should not be on)
2. Hold down power button and then turn on back power switch.
3. Listen for first beep
4. Listen for second beep
5. After you hear the second beep let go
The screen should appear. And remember, this will have to be done anytime you change TVs or change between HDMI and AV. Hope this was the problem and that it helps.
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
TV won't turn on.
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
May 31, 2007 | Zenith IQB36B42W TV
Televison & Video Logo
760 people viewed this question
Top Televison & Video Experts
