Question about Sharp AR-5320 Black and White Copier
Sharp AR-5330 Blinking "CH"
We recently received new toner for our AR-5320. The toner cartrigde is a AR-016TD. It has difficulty fitting into the machine. I can get it to fit sometimes but not always. I even turned the white gears on the ends in hope that the teeth in the gear not lining up was our problem. I was able to get the blinking CH to stop when doing this. We recently had a power surge and the blinking CH is back. I've tried everything I did before to make it go away but it is still blinking. I don't think these new cartidges fit very well as they are shaped slightly different. I am able to get the cartridge to insert all the way...at least it appears so. I've opened and closed all the doors on numberous occations with no luck. I am in a remote area of Afghanistan so no hope in getting a repairman out our way anytime soon. Please help.
  • garuda Jul 17, 2008
    I realize the Blinking CH means the DV is not installed correctly but ours is...is there any other troubleshooting for this error. These new AR-016Td toner cartidges aren't helping matters.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Here is my site check all the links whenever you have a problem
http://checkitright.spruz.net/?page=dp&dis=834222
"CH" Error Loo k this link for the code
http://www.copier-help.com/copier-help/ecs/sharp/ecssf7800.html
Developper not installed: check wires, contacts, lever
Posted on Jul 15, 2008
  • CheckitRight
    CheckitRight Jul 17, 2008
    Only advice I can give is to have both cartridges side by side and see what the differences are. If it's the gears un the back of the toner cartridges can you swap them ? protruding piece of plastic, break it ? Otherwise call the supplier and see what they say, a lot of times they already know the problem and can help.
    Good Luck.
MY SHARP AR-5320 DIPLAY 4 FOLLOWED WITH CH
HI
You have a door open somewhere, or no toner installed.
Cheers
Sep 02, 2014 | Sharp AR-5320 Black and White Copier
Sharp ar-5320 ch error
Side door open.
-check that all the side doors are closed. ok
Aug 27, 2014 | Sharp AR-5320 Black and White Copier
5520 sharp ch eror
If CH is still ,your machine's side cove or front cover is not Fully close.
If CH is blink, Toner Cartridge of toner chip is out of your machine, Or toner chip is damaged
Feb 11, 2014 | Sharp AR-5320 Black and White Copier
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
NOT PRINTING,ERROR CH,BLINKING RED TRIANGULAR LIGHT POINTING TO TRAIL
toner light needs to be reset.
(Then again you should throw out the old beast and get something new.)
Jan 15, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar 5320 error code f2
Dear sir.
I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
With beast regards
sayed Masood Osmani
Nov 22, 2007 | Office Equipment & Supplies
Sharp AR-5320 Black and White Copier Logo
185 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
