Retrace Line Fault
I have Samsung Plano Flat TV Model CZ21K5VB. I have replaced the defective FBT beaing Model FUH 21A001B(S) with the same make of the Chinease Model. But I'm finding retrace line fault.
Kindly suggest what to do.
Thanks.
R.N.Prasad
techman
  • 3130 Answers
SOURCE: Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Posted on Mar 26, 2006
SOURCE: av32d305 yaa retrace line on the top of the picture
yes on the top of the picture
Posted on Nov 29, 2007
  • 2326 Answers
SOURCE: retrace lines in top of tv...
These lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. The values of the capacitors are between 1uF, 10uF or possibly a 47uF.
I do not have the service manual at this moment but you can google it by the model number of your TV.
Let me know if you need further assistance.
Posted on Jun 16, 2009
welcomejee
  • 10594 Answers
SOURCE: SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Posted on Aug 14, 2009
SOURCE: TELEVISION CHASIS HAVING TDA 9370 SINGLE IC
Try zener from abl.
Posted on Sep 13, 2010
Is Samsung plano DNIe Jr 21 inch a flat TV model; kindly confirm
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 25, 2015 | Samsung Televison & Video
Samsung PU50A450P1O ve4tical retrace lines
Line, faults & possible causes for both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 28, 2014 | Televison & Video
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
Aug 13, 2014 | Samsung Televison & Video
Dear sir as im facing a problem in my sansui pj42multiplex that the fbt has got spark and the tv gone into standby....but after replacing the fbt the set dosent goes to power on mode...kindly help me
That sounds like the uProcessor has been damaged by the static discharge when the fbt arced out. Unfortunately this sort of added fault is common.
Check there is oscillator at the uProcessor. If there is then the fault is possibly elsewhere and the next stage is the line oscillator control board signals.
Mar 02, 2011 | Televison & Video
I WAS WATCHING MY SAMSUNG TV MODEL LN32A450C1DXZA AND WHITE LINES APPEARED ON 3/4 OF THE TOP PORTION OF THE SCREEN, HAD THE TV FOR ONLY FOUR YEARS
This fault is due to leakage of electrolytic capacitors in the vertical stage that is why top retrace lines are visible over the picture,if you are technical person check the capacitors in the vertical stage by replacing the same.
Jan 22, 2011 | Samsung Televison & Video
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
Tv takes up to four minutes to turn on and when it does it has distorted red lines running verticaly across the screen
is there retrace line with red colour then off agian.if yes there is red gun problem which is shorted with ground.you have to do give another way heater ac voltages or replace picture tube.
Oct 16, 2010 | Samsung Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
