Question about Jensen VM9411 Car Video Player
Bypass code does the vm9411 have a bypass code so i dont have to put the car on the emergency brake so i can watch a movie
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
When i put in a dvd the screen stays blue and says "warning stop watch video player" how do i get the movie to play?
their should be a safty wire run to the emergency brake that allows video only when the brake is set to bypass it you would need a relay wich you can get at autoparts store check out youtube for video on how to wire the relay
Jun 25, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
I have pioneer z2.i want to bypass emergency brake sensor so i can watch movies while driving.any ideas on how to do this
push ur emergency brake in only one click this will not affect ur driving or gas acceleration at all but will allow u to drive and watch ur dvd at the same time
Jun 22, 2010 | Car Audio & Video
Jensen VM8113 how do i bypass the pink wire(emergency break)
I have this exact same unit in my car. All you have to do is connect the pink emergency brake wire to your ground wire. Your dvd's will play if the car is moving or not.
Jan 29, 2010 | Car Audio & Video
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Bypass brake
What kind of vehicle? If you can find where the wire to the emergency brake switch (usually there is a switch at the top of the emer/brake pedal) was tapped into. Take a a test light (Bought at auto supply store) and find out if your switch is grounded or has 12vdc when emerg/brake is depressed. If it is grounded then find the wire from th dvd player and attach it to a frame ground. If it is 12vdc find some other source of 12vdc in the fuse box and put the wire to that source. If I knew what type of vehicle I can possible walk you through it.
Feb 02, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Tv has sound but no picture
Should be the same bypass. Do you get any message when you put it on a TV station? Guess what, after Feb 17th, it won'y matter anyway unless you're going to get a digital converter for it!
Try grounding the pink brake wire and see if that does anything. As far as I remember, that bypass is for ALL video on the screen. Let me know.
Peace,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Jensen VM9411 Car Video Player
Car Video Players
The emergency brake sequence is simple. First apply your emergency brake, or engage your toggle switch on keep it on for 3-5 seconds then release or disengage for 3-5 seconds then reengage and a couple of seconds later you have vidieo. ENJOY.
Oct 14, 2008 | Car Audio & Video
Jensen model#vm9411
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the blue one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Feb 25, 2008 | Jensen VM9411 Car Video Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
How do you install the dvd portion so i can view movies
I have Jensen VM9411 I put code 1264 and disable my remote control now is not working and my screen is not working
Aug 22, 2007 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
113 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
