Question about RCA DRC8335
Unit lockup cause
Hey i had the same unit and couldn't find my reciept so I disassmbled it.(keep in mind that I build computers so i'm somewhat of a techie) Anyways, I found that the circuit board for the dvd player (which also has the front panel controls routed through it for both dvd and vcr) was burned in more than four places. 2 of the capacitors had blown as well. I removed the burned board so if you need it for any legal matters email me at alexandreatta{@}yahoo.com "retype email without parentheses"
  • Anonymous Oct 07, 2008
    My RCA DRC8335 Just crapped out! I was trying to turn on the unit, to watch the stock markets crashing.... it was froze on "HELLO" for 15 minutes. This was not the first time. I struggled to get Customer support to access this issue, but they refused... since its a year old. They thought that If I took it back, I'd get a refund. Well, 90 days was the cutoff.
    I called the tech number (different than the one stuck to the unit). They were not open. I'm not shocked! If they use Indian Customer Service Reps, anything goes, even closing at 10 am on a weekday.
    I then called a TV repairman... RCA seems to have programming issues, besides the burnt boards.
    Too bad it's gone. I know of only a few VCR/DVD recorders that use NTSC and ATSC tuning. Now, i cannot get Canadian news, which reports about USA news, more than the USA does.
    I'll never buy another RCA.
    By the way, unplugging it, pressing "off" button 30 seconds, and even opening the top to cool... did not help.
  • emmgeeimage Oct 07, 2008
    was the cutoff.
I had similar problems with the Units (yes plural because they sent me a second replacement that didn't even turn on) and customer service...or the lck thereof. I finally wrot to the BBB and Thomson is alledgedly processing a refund. Suggest you do the same and by a unit from someone else!
Posted on Oct 03, 2008
    Problem Solver:
  • 3 Answers
Thanks for the information. We sent in our unit and just got a new one back yesterday. Of course the very same model....asked for something else based on so many complaints with this one.
Are you saying that it could be a fire hazard? I am a little afraid to try this new unit, if that is the case. Do you feel a new circuit board would be available? Are you planning on just replacing the board yourself? If it is a fire hazard then perhaps RCA should have a re-call on this unit. Have you informed them about the problem you found? Not really your job to do so, but I am wondering if you did notify them if you got a reply.
Thanks again for your help..... I will keep your email address.
Posted on Aug 15, 2008
0700 codes after replacing speed sensors
Hi there:DTC P0700 is a generic warning code that advice about a transmission fault specific code stored there. In this case, your addicional specifi code is P0740.
DTC P0740 - Torque Converter Clutch control circuit (A/T Torque Converter Clutch - No RPM Drop At Lockup)
This can be caused from as little as a blown fuse or bad ground to a bad valve body in the transmission. I would suggest a transmission shop to further diagnose since there are pressures that need checked and circuits that will need checked with diagnostic equipment. Here is a description and the testing procedure for DTC P0740. Keep in mind that there is a good chance the trans will need rebuilt.
Possible Causes:
Internal transmission component fault (Input or Reaction shaft) Internal transmission leakage (valve body leaking or seal rings) Converter clutch valve or clutch timing valve is sticking TCC assembly has failed.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 08, 2012 | Dodge Grand Caravan Cars & Trucks
Hi! I'm thinking about building my first pc, i already know what GPU and CPU i want, but i'm clueless as to what motherboard i need to buy... CPU: http://ark.intel.com/Product.aspx?id=52213 GPU:...
Hello and Welcome to FixYa!
You simply need the Motherboard for Core i7 processors, the Graphic unit you specified needs a PCI Express slot, which will b obvious in a board supporting i7s.
The top 2 getting in my mind are Intel® Desktop Board DX58SO and GIGABYTE GA-EX58-UD3R
For more goole for i7 motherboards, and you will get tons of them. Better go for Intel. (Just a suggestion)
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 24, 2011 | Computers & Internet
Will not dry cloths,have disassmble dryer and clean,check blower wheel for tightness
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Bios update
I doubt that a bios update. 99.9% of all bios don't need to be updated. The most common causes of lockups are video or ram memory related problems. More information is needed to correctly diagnose the problem here such as Operating system, what you're doing at the time of the lockups, what kind of hardware you have in your computer and what kind of software you're running. Also need to know if this is a new system or has it been running for a while before this started. You can also try downloading and running this diagnostic but you'll need a system with a CD writer to create this disc. http://technet.microsoft.com/en-us/magazine/2008.09.utilityspotlight.aspx?pr=blog
Dec 02, 2009 | Biostar G31-M7 TE Motherboard
My speedometer broke which in some didn't send a signal to the transmission that it had to be cooled. I burned up 2 transmissions in less 3 days...this is related to lockup....Can someone tell me what...
Lock up is a feature within the transmission torque converter which is a fuel saving measure.At cruising speeds,the torque converter "locks up" creating a 1:1 ratio from engine rpm to transmission input.This is somewhat like overdrive in a sense. TCC (torque converter clutch ) depends on the vehicle speed sensor input to determine cruising speeds and conditions where TCC is permissable.Incorrect TCC operation can cause subsequent damage and/or serious driveability problems.
Jul 09, 2009 | 1995 Toyota 4Runner
Golglogix locking up
Make sure to wait until you press okay on your computer when loading courses before you unplug the unit. I was jumping the gun, unplugging it right when it turned off, and causing that issue myself with mine.
Jun 22, 2009 | Garmin GolfLogix GPS-8
Compaq desktop freezes on me when am working
check the viruses in your system why freeze that... if the same problem after that try to reinstall the os
check another parts
Jun 07, 2009 | Computers & Internet
Freezes evry once in awhile...don't know why or how to fix??help!:)
Lockups are caused by one of 3 things. Malware *viruses*, Bad/Missing Drivers, or heat. Run an updated virus scan first, then check your drivers, make sure everything is new. If it's not one of those, then heat build up is causing the issue. Have a tech look at the unit.
Apr 29, 2009 | Computers & Internet
Brakes
calipers stiff moving or slide bolts seized in the bore
Jul 12, 2008 | 1990 Chevrolet K1500
Need a reciept
Hey Javi crunkk,
I am assuming you purchased the camera from a Best Buy™ store. Most of the time a store could pull up a copy of your receipt with payment information and print it out for you. If they are unable to find your receipt I would advise you to contact 1-888-Best Buy™. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 19, 2008 | Nikon COOLPIX S200 Digital Camera
RCA DRC8335 Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
